查看: 1041|回复: 6
[编程申请]:标注坐标
发表于 2004-3-12 19:47:51 | 显示全部楼层 |阅读模式
如何一次性标注所有点、圆心、直线与直线交点的坐标?
发表于 2004-3-12 20:10:04 | 显示全部楼层
一次性标记坐标?那重叠怎么办?
 楼主| 发表于 2004-3-15 18:18:18 | 显示全部楼层
我手上有个一次性表示所有直线端点坐标的程序,但是,我现在只要标注圆心,而不是直线端点阿!
发表于 2004-3-15 18:57:00 | 显示全部楼层
你手上有程序,能分享代码吗?
 楼主| 发表于 2004-3-16 23:12:36 | 显示全部楼层
可以,但是那是个vba程序!
发表于 2004-3-16 23:20:57 | 显示全部楼层
好啊,把它发上来吧!
 楼主| 发表于 2004-3-17 11:49:50 | 显示全部楼层
好,我看看!源代码如下:
Private Sub CommandButton1_Click()
Dim bzwu As AcadSelectionSet
Dim respond As String
Dim msg As String
Dim bzline(1000) As AcadLine
Dim hualine As AcadLine
Set bzwu = ThisDrawing.PickfirstSelectionSet
If bzwu.Count <> 0 Then
MsgBox "选择了" & bzwu.Count & "个直线进行标注"
Else:
  respond = MsgBox("请先选择直线之后再运行程序", 0, "警告")
  If respond = vbOK Then
  End
  End If
End If
Dim i As Integer
Dim n As Integer
Dim zbtextsx As AcadText
Dim zbtextsy As AcadText
Dim height As Double
Dim zbtexty As String
Dim zbtextx As String
Dim bzp1(0 To 2) As Double
Dim bzp2(0 To 2) As Double
Dim bzp3(0 To 2) As Double
Dim bzp4(0 To 2) As Double
Dim blc As Single
blc = TextBox1.Text
n = bzwu.Count
height = 3# * blc / 1000
Dim st(0 To 2) As Double
st(0) = 0: st(1) = 1: st(2) = 0
For i = 0 To n - 1
Set bzline(i) = bzwu.Item(i)
zbtexty = Left("Y=" & bzline(i).StartPoint(0), 12)
zbtextx = Left("X=" & bzline(i).StartPoint(1), 13)
If OptionButton1.Value = True Then
bzp1(0) = bzline(i).StartPoint(0) + 10 * blc / 1000
bzp1(1) = bzline(i).StartPoint(1) + 10.1 * blc / 1000
bzp1(2) = 0
bzp2(0) = bzline(i).StartPoint(0) + 10 * blc / 1000
bzp2(1) = bzline(i).StartPoint(1) + 10 * blc / 1000
bzp2(2) = 0
bzp3(0) = bzline(i).StartPoint(0) + 10 * blc / 1000
bzp3(1) = bzline(i).StartPoint(1) + 6.9 * blc / 1000
bzp3(2) = 0
bzp4(0) = bzline(i).StartPoint(0) + 40 * blc / 1000
bzp4(1) = bzline(i).StartPoint(1) + 10 * blc / 1000
bzp4(2) = 0
Set zbtextsx = ThisDrawing.ModelSpace.AddText(zbtextx, bzp1, height)
Set zbtextsy = ThisDrawing.ModelSpace.AddText(zbtexty, bzp3, height)
Call ThisDrawing.ModelSpace.AddLine(bzline(i).StartPoint, bzp2)
Call ThisDrawing.ModelSpace.AddLine(bzp2, bzp4)
Else
bzp1(0) = bzline(i).StartPoint(0) - 36 * (blc / 1000)
bzp1(2) = 0
bzp2(0) = bzline(i).StartPoint(0) - 10 * blc / 1000
bzp2(2) = 0
bzp3(0) = bzline(i).StartPoint(0) - 36 * (blc / 1000)
bzp3(2) = 0
bzp4(0) = bzline(i).StartPoint(0) - 40 * (blc / 1000)
bzp4(2) = 0
End If
Next
UserForm1.Hide
End Sub
Private Sub CommandButton2_Click()
End Sub
Private Sub OptionButton2_Click()
End Sub
Private Sub TextBox1_Change()
End Sub
Private Sub UserForm_Click()
End Sub
Private Sub UserForm_Initialize()
TextBox1.Text = 1000
End Sub
GMT+8, 2026-11-6 22:59 , Processed in 0.461673 second(s), 44 queries , Gzip On.
