查看: 2031|回复: 1
[求助] 关于改变多段线及直线的线型和线宽的问题
发表于 2019-1-10 11:43:15 | 显示全部楼层 |阅读模式
自己尝试结合发现
lisp中AB 二段保留其中一段
要么只支持多段线的线型及线宽转换
要么只支持直线的线型及线宽转换
有没人知道怎么结合
让代码反应到当前选的无论是直线还是多段线
都能帮你转换到相应的线型及线宽
另外还有没可能全选对象后全转换
感谢了
最后代码供上
(defun c:TTT(/ ent)
   (setq ent(ssget))
   (command "change" ent "" "p" "lt" "DASHDOT" "s" "15" "C" "2" "")
   (command "PEDIT" ent "W" "5" "")       ;适用于多段线; a
   (command "PEDIT" ent "" "W" "5" "")    ;适用于直线; b
(princ (strcat "\n提示:如未转换查看是否加载线型DASHDOT,\n"))
  (princ)
发表于 2019-1-10 12:42:29 | 显示全部楼层
回帖奖励 +6 D豆
  1. (defun c:TTT (/ ent oldcmd oldpe)
  2.   (setq oldcmd (getvar "cmdecho")
  3.         oldpe  (getvar "peditaccept")
  4.   )
  5.   (setvar "cmdecho" 0)
  6.   (setvar "peditaccept" 1)
  7.   (if (setq ent (ssget))
  8.     (progn (command "change" ent "" "p" "lt" "DASHDOT" "s" "15" "C" "2" ""
  9.                    )
  10.            (command "PEDIT" "M" ent "" "W" "5" "")
  11.            (setvar "peditaccept" oldpe)
  12.            (setvar "cmdecho" oldcmd)
  13.            (princ
  14.              (strcat "\n提示:如未转换查看是否加载线型DASHDOT,\n")
  15.            )
  16.     )
  17.   )
  18.   (princ)
  19. )
评分
参与人数 1D豆 +5 收起 理由
137407536 + 5 技术引导讨论和指点奖!
查看全部评分
GMT+8, 2026-11-22 07:49 , Processed in 0.280707 second(s), 12 queries , Gzip On, File On.
