查看: 1070|回复: 2
[求助]:如何让acedSSGet函数不选择锁定层上的实体?
已领礼包: 13个
发表于 2002-10-12 23:56:32 | 显示全部楼层 |阅读模式
如题
已领礼包: 145个
发表于 2002-10-13 10:17:26 | 显示全部楼层
Re: [求助]:如何让acedSSGet函数不选择锁定层上的实体?
最初由 LoveArx 发布
[B]如题 [/B]
  1. 在你使用acedSSGet获得选择集后,可以处理下选择集,把锁定层上的实体从选择集移走就可以了。给你贴个函数:
  2. [FONT=courier new]
  3. void ssNoLock (ads_name & tss)
  4. {
  5.         AcDbObjectId objId=AcDbObjectId::kNull;
  6.         AcDbEntity *pEnt=NULL;
  7.
  8.         AcDbObjectId layerId=AcDbObjectId::kNull ;
  9.         AcDbLayerTableRecord  *pLtblr=NULL;
  10.         ads_name eName;
  11.         long i=0;
  12.         if ( RTNORM == acedSSLength(tss,&i))
  13.         {
  14.                 /*        go through the selection set to get layerid and
  15.                         delete the entities on the locked layer from selection
  16. set*/
  17.                 for(long j=i-1;j >= 0;)
  18.                 {
  19.
  20.                         if (RTNORM == acedSSName(tss,j--,eName))
  21.                         {
  22.                                 if (Acad::eOk == acdbGetObjectId (objId ,
  23. eName))
  24.                                 {
  25.                                         if (Acad::eOk ==
  26. acdbOpenAcDbEntity(pEnt,objId, AcDb::kForNotify,Adesk::kFalse))
  27.                                         {
  28.                                                 layerId = pEnt->layerId();
  29.                                                 if (Acad::eOk ==
  30. acdbOpenObject(pLtblr,layerId,AcDb::kForRead,Adesk::kFalse))
  31.                                                 {
  32.                                                         if ( pLtblr->isLocked())
  33.                                                         {
  34.        //delete locked
  35. entity from selection set
  36.
  37.        if(RTNORM !=
  38. acedSSDel(eName,tss))
  39.
  40. acutPrintf("\nFailed to delete entity from selection set");
  41.        //close layer
  42. block table
  43.        if (Acad::eOk !=
  44. pLtblr->close())
  45.
  46. acutPrintf("\nFailed to close layer table record");
  47.                                                         }
  48.                                                 }
  49.                                                 else
  50.                                                         acutPrintf("\nFailed to
  51. open layer table record");
  52.        //close entity
  53.                                                 if (Acad::eOk != pEnt->close())
  54.                                                         acutPrintf("\nFailed to
  55. close entity");
  56.
  57.
  58.                                         }
  59.                                         else
  60.                                                 acutPrintf("\nFailed to open
  61. entity");
  62.
  63.                                 }
  64.                                 else
  65.                                         acutPrintf("\nFailed to open object");
  66.                         }
  67.                 } //for loop
  68.         }
  69. }
  70. //下面是上面函数的用法
  71. void mysel()
  72. {
  73.         ads_name ss;
  74.         if(acedSSGet(NULL,NULL,NULL,NULL,ss) != RTNORM)
  75.                 return;
  76.         ssNoLock(ss);
  77.         long len;
  78.         acedSSLength(ss,&len);
  79.         acutPrintf("\nGot %d entities",len);
  80.         acedSSFree(ss);
  81. }
  82. [/FONT]
复制代码
发表于 2002-10-13 10:32:36 | 显示全部楼层
最初由 LoveArx 发布
如题
1.遍历层表,取锁定层的层名列表
2.构造过滤条件,直接过滤即可
GMT+8, 2026-11-3 00:53 , Processed in 0.568236 second(s), 36 queries , Gzip On.
