查看: 924|回复: 1
[求助] [求助]:能动态的向注册表中读写系统时间吗?
发表于 2004-3-23 18:52:00 | 显示全部楼层 |阅读模式
我是这样写的,但调试后发现vl-registry-wrie函数中的<值>参数不能运算,比如
(setq date (rtos (getvar "cdate") 2 8)).........
(vl-registry-write "HKEY_CURRENT_USER\\Software\\Autodesk\\test"
                          "date")......
这样之后,到注册表中去查,结果是date,不是想要的时间。不知道怎么了。请斑竹指点。
下面是我想要达到目的的代码:
  1. (defun copyrighets-protected ()
  2.   ;;sub
  3.   (defun getvalue (vlist key)
  4.     (cdr(assoc key vlist))
  5.     )
  6.   ;;sub
  7.   (defun remainingday (nowday oldday)
  8.     (- (+ (* 356 (getvalue nowday "year")) (* 30 (getvalue nowday "month")) (* 1 (getvalue nowday "day")))
  9.        (+ (* 356 (getvalue nowday "year")) (* 30 (getvalue nowday "month")) (* 1 (getvalue nowday "day")))
  10.    )
  11.     )
  12.   ;;
  13.   (setq date (rtos (getvar "cdate") 2 8 ))
  14.   (setq year (read (substr date 1 4 ))
  15. month (read (substr date 5 2))
  16. day  (read (substr date 7 2))
  17. )
  18.   (setq nowdate (list (cons "year" year) (cons "month" month) (cons "day" day )))
  19.   (vl-load-com)
  20.   (if(not(setq registrydate  (vl-registry-read
  21.      "HKEY_CURRENT_USER\\Software\\Autodesk\\quickplotrights"
  22.      "registrydate"
  23.       )
  24.         )
  25.   )
  26.     (vl-registry-write
  27.       "HKEY_CURRENT_USER\\Software\\Autodesk\\quickplotrights"
  28.       "registrydate"
  29.       "nowdate"
  30.       )
  31.       (setq rday (remainingday nowdate (read registrydate)))
  32.     )
  33.   )
已领礼包: 593个
发表于 2004-3-24 06:51:39 | 显示全部楼层
Re: [求助]:能动态的向注册表中读写系统时间吗?
最初由 罗趣 发布
[B]我是这样写的,但调试后发现vl-registry-wrie函数中的<值>参数不能运算,比如
   ... [/B]
  1. (vl-registry-write
  2.       "HKEY_CURRENT_USER\\Software\\Autodesk\\quickplotrights"
  3.       "registrydate"
  4.       "nowdate"
  5.       )
改成
  3.       "registrydate"
  4.       (vl-princ-to-string nowdate)
  5.       )
GMT+8, 2026-11-4 06:22 , Processed in 0.490339 second(s), 33 queries , Gzip On.
