查看: 646|回复: 2
[SHARE]:Tuneup Utilities 2004 English
发表于 2004-4-2 22:14:04 | 显示全部楼层 |阅读模式
TuneUp Utilities(tm) 2004 optimizes the performance of your computer, solves problems and helps you to customize your system to suit your needs.
Extend your operating system's capabilities:
With TuneUp Utilities 2004, you can make Windows faster, more secure and comfortable. All important aspects of system configuration, setting up security, cleaning and maintenance are combined under a modern graphical user interface.
Features
NEW! The 1-Click Maintenance cleans your computer right from your desktop with only one click
NEW! Solves up to 400% more problems in the registry
NEW! Now also defragments the registry of Windows 2000/XP
NEW! Allows you to customize the look of all windows under Windows XP
Allows you to customize your system to your needs
Frees your computer of speed and hard disk space hogs
Optimizes the performance of your PC
Accelerates your internet connection
Frees up system memory
Gives you advice about your hardware and software
Recovers accidentally deleted files
Download:http://www.tune-up.com/files/TU2004TrialEN.exe
登录/注册后可看大图
[B]
KEY:
UserName: YeJun
Company : Pt
RegCode :83VK3-1EDAK-SV6AE-HN3N6-127H8-38SKA
[/COLOR]
[/B]
发表于 2004-4-2 22:26:19 | 显示全部楼层
楼主英语真不赖亚,整个没看见一个中文
和诺顿的功能差不多吧,英语不怎么样,看得不是太懂
发表于 2004-4-6 12:30:29 | 显示全部楼层
tuneup utilities 2003据说是史上最强优化软件(让兔子、大师下岗待业)!
tuneup utilities 2003 汉化注册版
软件语言: 简体中文
软件类型: 汉化补丁 / 系统工具 / 系统设置
运行环境: winxp, win2000, nt, winme, win9x
授权方式: 免费软件
汉化版下载地址:
相关链接: http://www.56666.com/tuneup.exe
软件简介: 德国系统调校工具第一品牌 - tuneup utilities,继 tuneup 97 在德国大卖三十几万份之后,再度推出 tuneup utilities 企图攻占系统调整工具国际市场!tuneup utilities 的功能应有尽有,主要工具包括:系统改造/分析、硬盘/登录文件清理、系统加速、记忆体最佳化、登录文件编辑、软件卸载、工作管理员、文件还原/清理。
tuneup utilities 2003 一款来自德国的系统优化软件,让你的系统跑的非常顺畅,功能全面,决不像兔子、大师使用后出现文件丢失现象,堪称极品!
注意汉化有一 bug 就是---------------------从注册表中不能读取disk清理器的设置,请重新安装tuneup utilities来解决这一问题.
解决办法!!
先安装英文版的,然后再用上面汉化的覆盖就不会出现“从注册表中不能读取disk清理器的设置,请重新安装tuneup utilities来解决这一问题。”的问题了,当然也可以磁盘清理了。
相关链接: http://www.tune-up.com/files/tu2003trialen.exe
注册码:
company:www.gupin.com
serial:5smgn-jm2ha-jsj8m-axysq-derct-7jskw
company: cs-skin.de.vu
code: gpdtj-p9178-twep6-1dxcq-u797c-fduu3
GMT+8, 2026-11-6 15:50 , Processed in 0.453218 second(s), 42 queries , Gzip On.
