查看: 989|回复: 1
[文章]:SurvCADD is the flagship product
发表于 2004-4-9 08:39:45 | 显示全部楼层 |阅读模式
SurvCADD is the flagship product of Carlson Software.
SurvCADD is sold in modules
that, taken together, cover virtually all aspects of surveying and site-based civil
engineering.
SurvCADD has evolved in tandem with the evolution of AutoCAD, and has
grown to become one of the premier 3rd party add-on products in the AEC
marketplace.
The COGO-DESIGN Module is all that is needed for downloading and entering field work
clear through design and drafting of the boundary survey or
subdivision plat. Working
on both English and Metric systems, the COGO-DESIGN Module provides clean, simple,
yet varied methods of survey
calculation.
The DTM Contour Module has helped build the reputation of SurvCADD and Carlson Software.
Commands such as Pad Template, Triangulate & Contour
and Volumes by Layer have led the
industry in simplicity and speed. SurvCADD's Contour-DTM Module was the first out with 3D
Polyline Offset,
Extend and Trim working within AutoCAD.
The 3D Polyline by Slope on
Surface continues to elicit wonderment in demos. So does Break 3D Polyline by Surface,
Drape 3D Polyline and Surface
Inspector. We at Carlson Software do 3D, we do DTM. It is
our forte, our comfort zone. You, too, will find your own comfort zone in Contour-
DTM.
Because it does difficult, time-consuming procedures fast with virtually no learning curve,
the Contour-DTM Module offers an exceedingly
quick return on investment. Right from the
start, it makes money for you.
The Section-Profile Module covers highway design, all forms of water,
sewer and other
utility profile work, cross sections and section-based volumes.
The module appeals to both civil engineering design firms and to construction companies
working from design plans.
Sections have a powerful input-edit feature that combines
keyboard entry with screen graphics, including outslope catch functionality that
mimics
templates. Advanced features include superelevation (per AASHTO), variable lane widths,
mass diagrams, flexible highway staging volumes
(partial lane construction), haul distance
analysis and cutsheets.
The Hydrology Module is the perfect companion to round out a suite of SurvCADD software
for the designer and engineer. It includes your
necessary design and analysis routines
for surface hydrology in the civil, mining, and engineering world. While linking to
SEDCAD, HEC-RAS and
HEC 2, SurvCADD utilizes the TR-20 and TR-55 methods for most types
of storm routing.
http://www.carlsonsw.com/survcadd.htm
Requirements: AutoCAD R14 through 2002
发表于 2004-4-15 13:27:41 | 显示全部楼层
有SurvCADDXML2的**吗?
GMT+8, 2026-11-22 11:33 , Processed in 0.318924 second(s), 13 queries , Gzip On, File On.
