查看: 978|回复: 9
[讨论]:MS自启动程序,进行如下设置
发表于 2004-4-12 14:29:52 | 显示全部楼层 |阅读模式
我想在MSJ中进行如下设置:
MSJ程序一启动,就运行一段自定义程序,类似于ACAD。LSP
MSJ中有没有???
发表于 2004-4-12 14:35:42 | 显示全部楼层
当然有了,不知道你自己定义的是什么程序?Ma文件还是MACROS?
要是MA文件的话,直接在DGNAPPS变量里面添加你要启动的MA文件就OK了!
 楼主| 发表于 2004-4-12 14:39:45 | 显示全部楼层
MACROS,在J版怎样设置??
发表于 2004-4-12 15:06:30 | 显示全部楼层
使用mdlapps下的runmacro程序,详细方法见说明。
发表于 2004-4-12 15:19:35 | 显示全部楼层
PIPI兄:如果不通过MDLAPPS不知道是否可以直接运行MACROS?
发表于 2004-4-13 12:51:10 | 显示全部楼层
可以试试用workspace/configuration/user commands/startup user command
 楼主| 发表于 2004-4-16 13:37:56 | 显示全部楼层
多谢各位!已经搞定!
发表于 2004-4-16 14:21:06 | 显示全部楼层
用什么搞定的,把自己的经验讲出来!
 楼主| 发表于 2004-4-17 19:17:25 | 显示全部楼层
其实很简单,定制一个*.UCM,然后用六楼兄弟的方法
发表于 2004-4-19 13:24:30 | 显示全部楼层
Run commands when starting MicroStation
To run a macro or set of keyins when starting MicroStation, you can use the -s command line switch which dumps the contents of a "startup file" into the MicroStation key-in window for immediate execution.
For this to work, you'll need to append the MicroStation icon command line to read:
ustation.exe -sdrive\folder\file.txt For example: -sd:\temp\RunNow.txt
"d:\temp\RunNow.txt" would then contain any set of key-ins to be run immediatly when MicroStation is started:
lv=1;co=0;wt=0;lc=0;on-1-63;selv 1;fit;selv 1;macro scaletext
If you want to run the contents of the startup file during the design session, just keyin a @ followed by the name of your startup file. ie: @d:\temp\RunNow.txt. (By the way, a startup file is more commonly referred to as a script file.)
For more information about script and startup files, please refer to:
The Power of Keyins - Part 2
More information about command line switches can be found in:
Technote 7102 - MicroStation Command Line Options/Switches
GMT+8, 2026-11-3 20:59 , Processed in 0.754316 second(s), 51 queries , Gzip On.
