查看: 769|回复: 3
[求助]:请问在VB中如何让选择集只选择一条直线?
发表于 2004-4-12 15:29:22 | 显示全部楼层 |阅读模式
rt
发表于 2004-11-5 00:21:08 | 显示全部楼层
可以先用getpoint获得直线上的点,然后用选择集的SelectAtPoint方法就可以了
发表于 2004-11-5 18:13:45 | 显示全部楼层
GetEntity,下面的代码没有做错误处理,自己改改吧
Function SelectSingleLine() As AcadLine
On Error Resume Next
Dim Selected As Boolean
Dim obj As AcadEntity, pnt
Selected = False
Do While Not Selected
ThisDrawing.Utility.GetEntity obj, pnt
If Not obj Is Nothing Then
If UCase(obj.ObjectName) = "ACDBLINE" Then
Set SelectSingleLine = obj
Selected = True
End If
End If
Loop
End Function
Sub aaa()
Set a = SelectSingleLine()
MsgBox a.Handle
End Sub
发表于 2004-11-12 13:10:54 | 显示全部楼层
就是这样
GMT+8, 2026-11-3 13:20 , Processed in 0.703029 second(s), 37 queries , Gzip On.
