查看: 912|回复: 0
[推荐]:一個將AUTOCAD圖檔轉入WORD的好工具betterWMF4.02帶注冊碼
发表于 2004-4-16 11:14:36 | 显示全部楼层 |阅读模式
BetterWMF helps you inserting AutoCAD drawings into for example
MS-office documents. BetterWMF will improve the picture on the fly
for you:
- The size of the picture will exactly match the extents of the
  objects. No large empty border to fit the AutoCAD window.
- The picture is transparent, the background color is removed.
- You can assign line weights based on colors.
- In TILEMODE 0 you can merge paperspace and all viewports
- The picture can be converted to black and white.
GMT+8, 2026-11-23 22:10 , Processed in 0.160576 second(s), 10 queries , Gzip On, File On.
