查看: 852|回复: 5
[求助]:简单的Rectangle填充,有代码,不知道错在那里,谁能帮助我!!急急急急急急!
发表于 2004-4-20 13:04:48 | 显示全部楼层 |阅读模式
我急用,前面的帖子没有人回答,只好另粘一个,对不起!!
我按照咱们网站的以前的文章,做HATCH,但是不能实现,错在那里?
[php]
void zhupingmian(AcGePoint3d insertpt,double kuan,double gao,AcDbBlockTableRecord *pBlockTableRecord)
double m_RZuoTuBiLi(10.0);
int m_NID(0);
AcGePoint3dArray zhuppingmianptArr; zhuppingmianptArr.setLogicalLength(5);
zhuppingmianptArr[0].set(insertpt.x-kuan/2*m_RZuoTuBiLi,insertpt.y-gao/2*m_RZuoTuBiLi,0.0);
zhuppingmianptArr[1].set(zhuppingmianptArr[0].x,zhuppingmianptArr[0].y+gao*m_RZuoTuBiLi,0.0);
zhuppingmianptArr[2].set(zhuppingmianptArr[1].x+kuan*m_RZuoTuBiLi,zhuppingmianptArr[1].y,0.0);
zhuppingmianptArr[3].set(zhuppingmianptArr[2].x,zhuppingmianptArr[0].y,0.0);
zhuppingmianptArr[4]=zhuppingmianptArr[0];
AnyPline(zhuppingmianptArr,2,pBlockTableRecord);
AcGePoint2d temp;
AcGePoint2dArray External;
AcDbObjectId FillId=plineObjId[m_NID]; m_NID=m_NID+1;
for (int i=0;i<5;i++) {
temp.set(zhuppingmianptArr.x,zhuppingmianptArr.y);
External.append(temp);
} //填加区域点
AcDbHatch * pHatch = new AcDbHatch();//创建图案填充对象
AcGeVector3d normal(0.0,0.0,1.0);
pHatch->setNormal(normal); //设置法线适量
pHatch->setElevation(0.0); //设置绘图标高
pHatch->setAssociative(Adesk::kFalse);
pHatch->setPatternScale(0.1); //设置缩放比例
pHatch->setPattern(AcDbHatch::kPreDefined,"ANSI31"); //设置填充图案
pHatch->setHatchStyle(AcDbHatch::kNormal); //设置填充样式
pHatch->setColorIndex(1); //设置剖面线颜色
pHatch->setLayer("0"); //设置所在图图层
AcGeDoubleArray vertexBulges;
vertexBulges.setPhysicalLength(0).setLogicalLength(5);
for (int j=0;j<5;j++) vertexBulges[j]=0.0; //清零
//边界生成:外边界
if (pHatch->appendLoop(AcDbHatch::kExternal, External, vertexBulges) != Acad::eOk) {
ads_printf("\n错误:无法形成填充外边界!\n");
pHatch->close();
if (pHatch->evaluateHatch()!=Acad::eOk) { //用设定的剖面线样式填充
ads_printf("\n错误:无法用设定的剖面线样式填充!\n");
pHatch->close();
if (pBlockTableRecord->appendAcDbEntity(FillId, pHatch) != Acad::eOk) {
ads_printf("\n错误:无法将填充实体填加至数据库中!\n");
pHatch->close();
[/php]
BUG为不能将当前数据库使用SAVEAS保存为一个DWG文件,提示写文件错误!
运行没有问题,但是不能实现功能!!!,实在很急,望各位赐教,跪求!!!!!!!!!!!!!
各位仁兄仁弟靓姐靓妹帮忙啊,!!!
已领礼包: 145个
发表于 2004-4-20 13:30:00 | 显示全部楼层
Re: [求助]:简单的Rectangle填充,有代码,不知道错在那里,谁能帮助我!!急急急急急急!
最初由 boust 发布
[B]我急用,前面的帖子没有人回答,只好另粘一个,对不起!!
[php]
void zhupingmian(AcGePoint3d insertpt,double kuan,double gao,AcDbBlockTableRecord ... [/B]
你把提示的弹出窗口的文字截图贴到论坛来吧。
已领礼包: 192个
发表于 2004-4-20 13:40:46 | 显示全部楼层
你的pBlockTableRecord 处理了吗?
 楼主| 发表于 2004-4-20 17:05:47 | 显示全部楼层
pBlockTableRecord 我在主调函数中已经处理过了,
只是我在主调函数中加入如下代码,提示处错,不加SAVEAS代码,程序运行没有问题,但是不
实现我的HATCH 功能。
pDb->saveAs("D:\\个人目录\\论文目录\\jgt.dwg");
程序提示---------------------------
AutoCAD 信息
写入/关闭文件时出错。
确定
而且我的HATCH功能没有实现。我吧ASNI替换成SOLID也不行,XD斑竹你测试我的代码了吗?
另外,我想把贴图贴倒论坛,但是不知道如何贴图。
已领礼包: 145个
发表于 2004-4-20 17:10:43 | 显示全部楼层
最初由 boust 发布
[B]pBlockTableRecord 我在主调函数中已经处理过了,
实现我的HATCH 功能。
pDb->saveAs("D:\\个人目录\\论文目录\\jgt.dwg")... [/B]
一步一步来吧,贴图,首先你要会“截取图形”,使用SNAGIT等软件做,发贴的时候,附件里面点浏览,选上你硬盘的图片文件,就和帖子一起发论坛来了。
你保存的目录名用英文的试试,看看结果。
 楼主| 发表于 2004-4-20 17:38:10 | 显示全部楼层
问题解决了,
我还得谢谢XD,我还是忘了        pHatch->close();
了了了了了了了了!!!!!!!!!!!!!!!!!!!!!
真是教训不小啊,害得我好厂时间在调试!!!!
GMT+8, 2026-11-5 10:57 , Processed in 0.382416 second(s), 42 queries , Gzip On.
