查看: 2395|回复: 33
[原创]:想知道AutoCAD的下一个版本是怎么样的吗?——红鹿行动
发表于 2002-11-5 01:55:18 | 显示全部楼层 |阅读模式
哈哈哈,其实我也在看,程序我还没有哦,别找我要!
至于变更的地方我可以翻译过来给大家看看!
代号红鹿Red Deer的新版ACAD,即将面世!
过两天我翻译好了就给你贴上;)
已领礼包: 24个
发表于 2002-11-5 16:32:45 | 显示全部楼层
在哪里?给出链接吧?
在autodesk网站上看不到啊?
发表于 2002-11-7 20:58:36 | 显示全部楼层
别让我们等得心焦,先给个e文的也行啊
发表于 2002-11-8 21:24:46 | 显示全部楼层
有必要的吗?
我觉得现在的已经很不错了
学好当前版本的就已经可以成为绘图高手了
cad是用的
只要能画好图就够了
没有什么必要去追求最新的版本吧?
发表于 2002-11-9 15:29:35 | 显示全部楼层
楼上老兄说得对,主要是软件的掌握,版本其实并不重要。
:1
发表于 2002-11-9 23:33:43 | 显示全部楼层
我用过的CAD从R10-2002。如果以目前我等机子配置,在一文件中做40张以上的图,还是非R14莫属,当然R10-12也可,但用来不方便。不知仁兄们有何看法?不过像XD兄等要参加“华山论剑”的绝世高手们不断发掘新的“武功秘籍”当然无可厚非。AUTODESK为赚钱要不断出新,直至吸完大家的血为止,故此奉劝大家还是少赶热闹为妥。
发表于 2002-11-11 12:41:29 | 显示全部楼层
觉得新版本有许多好处,例如方便操作,功能也多,我是一直在用最的.
 楼主| 发表于 2002-11-12 03:08:08 | 显示全部楼层
“马鹿”将提供全信的功能以及大范围增强功能:
• 易用性
• 协调性
• 性能和管理
Ease of Use
Red Deer offers a new easy-to-use palette interface, time-saving xref functionality, as well as many drafting enhancements.
Palettes
A new palette interface in Red Deer offers time-saving functionality to new and existing tools.
Tool Palettes
New customizable tool pallets provide easy access to frequently used drawing content including blocks and hatches. You can save time finding and inserting existing drawing content into your designs.
Red Deer includes three sample palettes to introduce you to this valuable new functionality.
You can modify the existing palettes or add new ones.
Figure 1 Default Tool Palettes Context
Context sensitive menus provide access to controls for palette tools and the palettes themselves.
 楼主| 发表于 2002-11-12 03:13:01 | 显示全部楼层
Managing Palette Tools
The context menu displayed by right-clicking over a tool within a palette enables you to manipulate individual tools including the ability to apply specific properties to that tool.
In the Tool Properties dialog box, you can assign general properties such as color layer and linetype to your tools. In addition, you can assign properties that are specific to the type of tool. For example, with block tools you can assign scale and rotation values and with Hatch tools you can assign pattern and angle values. This powerful functionality enables you to maintain consistency while significantly increasing productivity.
 楼主| 发表于 2002-11-12 03:18:23 | 显示全部楼层
Figure 2 Tool Properties dialog box for blocks and hatches
You can easily populate tool palettes with your most frequently used blocks and hatch patterns using the DesignCenter.
Managing Palettes
Depending on the location of your cursor, right-clicking over a tool palette displays different versions of the context menu.
 楼主| 发表于 2002-11-12 21:11:38 | 显示全部楼层
Figure 3 Palette context menus
View Options enable you to modify the appearance of the tools to suit your own environment. Detailed tool descriptions make new tools easier to learn. You can switch to simplified iconic tool displays to save screen real estate when you are familiar with the tool.
You can apply the specified view options to individual palettes or to all of them at once.
 楼主| 发表于 2002-11-12 21:20:18 | 显示全部楼层
Figure 4 View Options dialog box
Right-clicking over
Customize enables you to add tool palettes using the new Palettes tab in the Customize dialog box. Additionally, you can control the order of the palettes, rename or delete existing palettes and even Import and Export Palette configurations for use on other systems.
 楼主| 发表于 2002-11-12 21:22:04 | 显示全部楼层
Figure 5 Palettes tab
Auto-hide functionality enables you can take advantage of increased screen real estate for
designing and drafting, while maintaining easy access to occasionally used tools. You simply pass your cursor over the minimized title bar and the full palette displays. As soon as you move your cursor away from the palette, it automatically minimizes. A pushpin preserves the expanded status of a tool palette enabling you to keep your most used pallets expanded all the time for immediate access.
 楼主| 发表于 2002-11-12 21:23:33 | 显示全部楼层
Figure 6 Palette with Auto-hide on and off.
Transparency saves you additional screen real estate by enabling you to see the drawing geometry beneath the palettes.
发表于 2002-11-12 21:24:08 | 显示全部楼层
哇,太。。。。。winxp化了。界面上有点骚。
GMT+8, 2026-11-4 02:53 , Processed in 0.729391 second(s), 61 queries , Gzip On.
