楼主: CCarch
[原创]:想知道AutoCAD的下一个版本是怎么样的吗?——红鹿行动
 楼主| 发表于 2002-11-12 21:25:04 | 显示全部楼层
Figure 7 Palette with Transparency turned on
The transparency level of individual palettes can be adjusted from completely opaque to barely visible. And with one simple click, you can turn off transparency for all palettes offering improved display performance on some systems.
 楼主| 发表于 2002-11-12 21:37:30 | 显示全部楼层
Figure 8 Transparency control dialog
Content Scrolling
When the size of a palette is less than is required to display all the content it contains, a scrollbar is automatically displayed near the edge of the palette. You can use the scroll bar to navigate up and down the palette or simply pan with the “hand” symbol that is displayed on the cursor. Content scrolling enables you to resize your palettes, increasing screen real estate, while maintaining easy access to tools.
 楼主| 发表于 2002-11-12 21:38:20 | 显示全部楼层
Figure 9 Palette with scroll bar displayed
Design Center
The Design Center in Red Deer has been redesigned to take advantage of the new palette interface. Four tabs provide quick access to folders, open drawings, history, and the new DC Online.
Design Center Online is a customer-supplied resource community of content for Autodesk customers. Registered members of Autodesk Point A can share and download content at no charge.
 楼主| 发表于 2002-11-12 21:40:45 | 显示全部楼层
Figure 10 DesignCenter Palette
You can use the DesignCenter to access content and quickly create palettes based upon block libraries. Create block palettes with one click based upon files or directories of files.
 楼主| 发表于 2002-11-12 21:42:42 | 显示全部楼层
Figure 11 Creating Palettes with DesignCenter
Property Palette
The Properties window has been updated with the new palette interface. In addition to the new look and feel, the Properties functionality has been enhanced by including access to block attributes. With the addition of the Attributes properties, you can quickly select, view, and modify attribute content of blocks directly from the Properties window.
 楼主| 发表于 2002-11-12 21:45:23 | 显示全部楼层
Figure 12 Property Palette with an attributed block selected
Another time-saving enhancement to the Properties window is the persistent property views. In Red Deer, the type of properties you display in the Properties window stay persistent with the object type until you change them. Suppose, for example, when selecting text objects, you typically want to view the Text properties, and when selecting Hatch objects, you typically want to view the Pattern properties. You simply select the properties you want to display for a specific object type once, and subsequent selections of that object type will automatically display that same type of information.
 楼主| 发表于 2002-11-12 21:49:58 | 显示全部楼层
Figure 13 Properties window with display information saved per-object type DB Connect
The DB Connect Manager, used to link drawing objects to database records, has been updated to include the new Palette functionality.
 楼主| 发表于 2002-11-12 21:53:24 | 显示全部楼层
Figure 14 DB Connect Palette
External References (Xrefs)
Red Deer greatly improves the way you work with externally referenced drawings. Xrefs in the host drawing honor the specified draworder as well as offering significant functionality related to management and editing.
Opening Xrefs
Red Deer introduces a new command, XOPEN, which enables you to quickly open an entire external reference in a new drawing window. You can enjoy the performance of working directly on an xref file while having the convenience of selecting the file from within the context of the host drawing.
With the host drawing open, you can simply select the xref you wish to modify and choose Open Xref from the right-click menu. You can even select multiple xrefs at the same time and each file will open in its own
drawing window!
The new XOPEN functionality is also available at the command line as well as in the Xref manager dialog box.
 楼主| 发表于 2002-11-12 21:54:48 | 显示全部楼层
Xref Manager
The Xref manager has been updated to include the new Open button enabling you to tag multiple xref files for open. New icons provide visual cues for the status of each Xref file.
Upon exiting the Xref Manager, all of the tagged files will automatically open in their own AutoCAD windows.
 楼主| 发表于 2002-11-12 22:00:50 | 显示全部楼层
Figure 15 Xref Manager with files selected to open
The Xref Manager and other Xref related tools have been enhanced to offer new resizable dialog boxes.
Xref Search Paths
Assigning and searching of Xref paths is easy and consistent. Attaching xref files in Red Deer enables you to specify a full or relative path. Relative paths of nested Xrefs are searched relative to their immediate host file, not the current drawing.
 楼主| 发表于 2002-11-12 22:05:24 | 显示全部楼层
Figure 16 External Reference dialog box with path types displayed
Red Deer provides the following consistent search order for Xrefs:
• Explicit path associated with xref
• Current folder of host drawing
• Project paths
• Support paths
• Start-in folder
 楼主| 发表于 2002-11-13 00:07:19 | 显示全部楼层
Drafting Enhancements
MText
Valuable enhancements made to the Mtext editor offers easy, time-saving functionality for creating and modifying text in drawings.
Key functionality includes:
• A new frameless editor
• A new context menu
• Support for tabs and indents
• Full display text drag
Creating new Mtext or double-clicking on an existing Mtext object displays the new frameless editor with ruler as well as the Text formatting toolbar. If you are zoomed out from the text so that it is too small to read, the Mtext editor will display it in an enlarged view. If you are zoomed too close to the text, the editor will display it in a reduced view. If the current display of the text is visually appropriate, the Mtext editor will maintain the visual size of the text in the editor.
 楼主| 发表于 2002-11-13 00:09:38 | 显示全部楼层
Figure 18 Mtext editor and Text Formatting toolbar
A context menu as well as the Text formatting toolbar provides quick access to commonly used text editing tools such as height and changing case.
Using the ruler at the top of the frameless editor or the new Tabs and Indents dialog box you can quickly create and modify paragraph tabs and indents.
发表于 2002-11-13 00:29:12 | 显示全部楼层
总结一下新版本的特点:
屏幕越来越小
垃圾越来越多
机器越来越好
速度越来越慢
价格越来越高
用户越来越穷
 楼主| 发表于 2002-11-13 02:19:48 | 显示全部楼层
最初由 archt 发布
[B]总结一下新版本的特点:
小/多/好/慢/高/穷 [/B]
精辟,有道理!
老清好久没有露面了,去哪啦?
关于R16,还有很多,慢慢来
GMT+8, 2025-11-10 09:25 , Processed in 0.506471 second(s), 53 queries , Gzip On.
© 2001-2025 Discuz! Team.
