查看: 948|回复: 3
[求助]:请大家帮忙看一下一个简单的代码
发表于 2004-4-27 15:57:59 | 显示全部楼层 |阅读模式
Private Sub CommandButton1_Click()
Dim AcadApp As AcadApplication
Dim StyObj1 As AcadTextStyle
Dim Bold As Boolean
Dim Italic As Boolean
Dim charSet As Long
Dim typeFace As String
Dim PitchAndFamily As Long
Set StyObj1 = AcadApp.ActiveDocument.TextStyles.Add("A1")
typeFace = "宋体"
Bold = True
Italic = True
charSet = 1
PitchAndFamily = 1 Or 16
StyObj1.SetFont typeFace, Bold, Italic, charSet, PitchAndFamily
textString = "AutoCAD"
height = 20
insertionPoint(0) = 5: insertionPoint(1) = 2: insertionPoint(2) = 0
AcadApp.ActiveDocument.ActiveTextStyle = StyObj1
Set textObj = AcadApp.ActiveDocument.ModelSpace.AddText(textString, insertionPoint, height)
textObj.Update
运行时出错,提示行:Set StyObj1 = AcadApp.ActiveDocument.TextStyles.Add("A1") 变量或with未定义?怎么回事呢?
发表于 2004-4-27 20:32:49 | 显示全部楼层
我觉得加字体和图层、标注样式等等可以考虑采用插入块然后再删除来实现
发表于 2004-4-28 08:23:00 | 显示全部楼层
Re: [求助]:请大家帮忙看一下一个简单的代码
最初由 sharksun 发布
[B]Private Sub CommandButton1_Click()
Dim Bold As Boolean
Dim charSet As Long
Dim PitchAn... [/B]
在这一行之前,要有:set acadapp = ........
发表于 2004-5-19 09:55:47 | 显示全部楼层
三楼说的不错,在操作acadapp对象之前要对其初始化。我想可以这样写:
on error resume next
set acadapp=GetObject("AutoCAD.Application")'先获得autocad进程
if err then
err.clear
set acadapp=CreateObject("AutoCAD.Application")'如果出错,创建进程
if err then
msgbox err.description
err.clear
end if
end if
GMT+8, 2026-11-3 20:47 , Processed in 0.555082 second(s), 38 queries , Gzip On.
