查看: 1064|回复: 7
[分享]:autohook2002-1.03-英文原版及汉化
发表于 2004-5-7 05:13:45 | 显示全部楼层 |阅读模式
今天晚上在到处找autohook2002-1.03-的英文原版,发现晓东给的明经的连接上也没有了,于是就去国外的网站上下了个,现在和汉化一起传上来,给还没有的朋友用
还有哈,是在CAD2002下面用的,不过我不太会用,希望高手指点一下,谢谢大家了
发表于 2004-5-7 08:25:24 | 显示全部楼层
楼主能说明一下它的运行环境么?2002?2004?2005?R14?
是做什么用的我现在还不知道呢?
能说明一下么?
谢谢!
发表于 2004-5-7 11:25:47 | 显示全部楼层
We at Command Digital Studios are efficiency freaks! We created AutoHook because we are too lazy to type commands and their options into AutoCAD. AutoCAD power users know that the keyboard is the fastest interface available for working with AutoCAD. AutoHook makes the fastest even faster by allowing you to customize your keyboard quickly and easily.
AutoHook is a tiny Windows tray application that "hooks" onto AutoCAD keyboard input. If AutoHook detects a key-press that has an assigned macro, the key is trapped and the macro is sent to AutoCAD. Sample macros are provided, but the real power is through your own customization.
AutoHook monitors all keyboard input to both the AutoCAD graphics window and the AutoCAD text window. AutoHook ignores all other windows and programs including AutoCAD dialog boxes. Mouse clicks and movements are also ignored (mouse is not supported - keyboard only).
AutoHook must be running (either windowed or minimized to the tray) for the macros to be recognized by AutoCAD. Your queue that AutoHook is running will be the addition of the text *Hooked* to the AutoCAD title bar. See preferences for information on changing the title bar text.
发表于 2004-5-10 19:42:55 | 显示全部楼层
и?璶いゅて?硁砰
谅谅だㄉ
发表于 2004-11-13 18:17:55 | 显示全部楼层
我安装了,怎么用不了?是不是这个版本不能用在2004?
发表于 2004-11-28 19:25:30 | 显示全部楼层
是不是已注册版?
发表于 2004-11-28 20:07:02 | 显示全部楼层
视野国际化点,不要老汉化
发表于 2005-4-25 20:06:22 | 显示全部楼层
英文不太灵光,还是喜欢用汉化的东西。谢了。
GMT+8, 2026-11-5 10:19 , Processed in 0.468866 second(s), 47 queries , Gzip On.
