查看: 732|回复: 2
[分享]:CloudWorx 2.1 -keymaker
发表于 2004-5-9 11:00:18 | 显示全部楼层 |阅读模式
R e l e a s e              I n f o
Bentley CloudWorx 2.1 delivers 3D point clouds created
     by high density laser scanners directly into the hands
of the designers and engineers who need accurate,
comprehensive as-built data. Bentley CloudWorx 2.1
provides immediate productivity, enabling you to easily visualize and work with point cloud data,
create accurate as-builts and topographic maps and   check proposed designs against existing site    conditions in a familiar CAD environment.       New interference detection capabilities enable you to     check designs for potential interferences with point  clouds and highlight interfering points based upon   user-defined parameters.                                              Bentley CloudWorx 2.1 provides two installation     options - MDL or ARX - enabling use with both
MicroStation and AutoCAD-based products offered by       Bentley.
发表于 2004-5-9 11:22:26 | 显示全部楼层
呵呵,我想这里没多少人用得起leca的激光扫描器吧
发表于 2004-5-13 13:15:19 | 显示全部楼层
能提供下载地址吗?
GMT+8, 2026-11-3 19:23 , Processed in 0.641893 second(s), 37 queries , Gzip On.
