查看: 1077|回复: 5
[弹指神通]:如何建立状态栏!
发表于 2002-11-14 18:00:02 | 显示全部楼层 |阅读模式
  1. [FONT=courier new]
  2. 在dlg的.h文件中加入:
  3.         CStatusBar                        m_StatusBar1;
  4. 在dlg的.cpp文件中加入:
  5. static UINT BASED_CODE indicators[] =
  6. //        static UINT indicators[] =
  7. {
  8.          //ID_SEPARATOR,
  9.      ID_INDICATOR_CAPS,
  10.      ID_INDICATOR_NUM,
  11.          ID_USER_STR,
  12. };
  13. 然后在.cpp文件OnInitDialog()中加入:
  14.         CRect        rcClientOld; // 久客户区RECT
  15.         CRect        rcClientNew; // 加入TOOLBAR后的CLIENT RECT
  16.         GetClientRect(rcClientOld); //
  17.         // Called to reposition and resize control bars in the client area of a window
  18.         // The reposQuery FLAG does not really traw the Toolbar.  It only does the calculations.
  19.         // And puts the new ClientRect values in rcClientNew so we can do the rest of the Math.
  20.         //重新计算RECT大小
  21.         RepositionBars(AFX_IDW_CONTROLBAR_FIRST,AFX_IDW_CONTROLBAR_LAST,0,reposQuery,rcClientNew);
  22.         // All of the Child Windows (Controls) now need to be moved so the Tollbar does not cover them up.
  23.         //所有的子窗口将被移动,以免被TOOLBAR覆盖
  24.         // Offest to move all child controls after adding Tollbar
  25.         //计算移动的距离
  26.         CPoint ptOffset(rcClientNew.left-rcClientOld.left,rcClientNew.top-rcClientOld.top);
  27.         CRect        rcChild;
  28.         CWnd*        pwndChild = GetWindow(GW_CHILD);  //得到子窗口
  29.         while(pwndChild) // 处理所有子窗口
  30.         {//移动所有子窗口
  31.                 pwndChild->GetWindowRect(rcChild);
  32.                 ScreenToClient(rcChild);
  33.                 rcChild.OffsetRect(ptOffset);
  34.                 pwndChild->MoveWindow(rcChild,FALSE);
  35.                 pwndChild = pwndChild->GetNextWindow();
  36.         }
  37.         CRect        rcWindow;
  38.         GetWindowRect(rcWindow); // 得到对话框RECT
  39.         rcWindow.right += rcClientOld.Width() - rcClientNew.Width(); // 修改对话框尺寸
  40.         rcWindow.bottom += rcClientOld.Height() - rcClientNew.Height();
  41.         MoveWindow(rcWindow,FALSE); // Redraw Window
  42.         RepositionBars(AFX_IDW_CONTROLBAR_FIRST,AFX_IDW_CONTROLBAR_LAST,0);
  43.         // TODO: Add extra initialization here
  44.         m_StatusBar2.CreateEx(this,SBT_TOOLTIPS,WS_CHILD|WS_VISIBLE|CBRS_BOTTOM,AFX_IDW_STATUS_BAR);
  45.         // Set the indicators namely caps and nums lock status
  46.         m_StatusBar2.SetIndicators(indicators,sizeof(indicators)/sizeof(UINT));
  47.         CRect rect;
  48.         GetClientRect(&rect);
  49.         //m_StatusBar.SetPaneInfo(0,ID_INDICATOR_CAPS,SBPS_NORMAL,rect.Width()/2);
  50.         //m_StatusBar.SetPaneInfo(1,ID_INDICATOR_NUM,SBPS_STRETCH ,rect.Width()/2);
  51. //        m_StatusBar.SetPaneInfo(0,ID_INDICATOR_NUM,SBPS_NORMAL ,rect.Width()/3);
  52.         m_StatusBar2.SetPaneInfo(0,ID_INDICATOR_CAPS,SBPS_NORMAL|SBPS_DISABLED,rect.Width()/3);
  53.         m_StatusBar2.SetPaneInfo(1,ID_INDICATOR_NUM,SBPS_NORMAL ,rect.Width()/3);
  54.         m_StatusBar2.SetPaneInfo(2,ID_USER_STR,SBPS_NORMAL ,rect.Width()/3);
  55.     m_StatusBar2.SetPaneText(2,"用户名称", TRUE);
  56.
  57.         //m_StatusBar.SetPaneInfo(1,ID_USER_STR,SBPS_STRETCH ,rect.Width()/3);
  58.         RepositionBars(AFX_IDW_CONTROLBAR_FIRST,AFX_IDW_CONTROLBAR_LAST,ID_INDICATOR_NUM);
  59.         m_StatusBar2.GetStatusBarCtrl().SetBkColor(RGB(180,190,190));
  60. 就加入了状态栏(基于dlg)[/FONT]
复制代码
已领礼包: 145个
发表于 2002-11-14 18:09:52 | 显示全部楼层
谢谢!大家以后贴代码的时候,希望用“格式化代码”的方法,论坛置顶的帖子里面介绍了方法。看下下面的帖子:
http://www.xdcad.net/forum/showthread.php?threadid=1080
发表于 2002-12-14 14:20:37 | 显示全部楼层
非常感谢,我也是个初学者
发表于 2005-8-11 22:59:28 | 显示全部楼层
我很早就想处理了,但没成功,让我试试,谢谢大公无私的楼主
发表于 2005-8-13 13:42:26 | 显示全部楼层
我也来试试看
还是不懂
那位高人解释一下啊
发表于 2005-8-15 17:39:14 | 显示全部楼层
我做出来了,跟楼主的方法是不同的,他的思路是正确的,但我却实现不了,等我整理好了在上传给大家
GMT+8, 2026-11-6 02:45 , Processed in 0.436830 second(s), 42 queries , Gzip On.
