查看: 1658|回复: 7
[VBA函数]:对扩展数据进行操作的函数
已领礼包: 181个
发表于 2002-11-14 19:11:57 | 显示全部楼层 |阅读模式
我编了两个函数,可以像属性操作那样方便的操作扩展数据。
  1.   [FONT=courier new]
  2. '获取扩展数据
  3. EntObj    包含扩展数据的对象
  4. Name     扩展数据的注册应用程序名称
  5. Tag        标签(唯一)
  6. Value     值
  7. Public Function GetXDataText(ByVal EntObj As AcadObject, ByVal Name As String, ByVal Tag As String) As String
  8.     Dim xdType As Variant
  9.     Dim xdData As Variant
  10.     Dim i As Integer
  11.     Dim temp As Variant
  12.
  13.     On Error GoTo ErrTrap
  14.     If EntObj Is Nothing Then Exit Function
  15.     If Name = "" Or Tag = "" Then Exit Function
  16.     GetXDataText = ""
  17.     EntObj.GetXData Name, xdType, xdData
  18.     If Not IsEmpty(xdType) Then
  19.         For i = LBound(xdType) To UBound(xdType)
  20.             If xdData(i) <> "" Then
  21.                 temp = Split(xdData(i), "=", , vbTextCompare)
  22.                 If Not IsEmpty(temp) Then
  23.                     If StrComp(temp(0), Tag, vbTextCompare) = 0 Then
  24.                         If UBound(temp) >= 1 Then GetXDataText = temp(1)
  25.                         Exit For
  26.                     End If
  27.                 End If
  28.                 temp = Empty
  29.             End If
  30.         Next
  31.     End If
  32.     xdType = Empty
  33.     xdData = Empty
  34.     Exit Function
  35.
  36. ErrTrap:
  37.     Debug.Print "GetXDataText: " & Err.Number & ", " & Err.Description
  38.     On Error GoTo 0
  39. End Function
  40. '设置扩展数据
  41. Public Sub SetXDataText(ByRef EntObj As AcadObject, ByVal Name As String, ByVal Tag As String, ByVal Text As String)
  42.     Dim xdType As Variant
  43.     Dim xdData As Variant
  44.     Dim i As Integer
  45.     Dim temp As Variant
  46.     Dim bExist As Boolean
  47.     On Error GoTo ErrTrap
  48.     If EntObj Is Nothing Then Exit Sub
  49.     If Name = "" Or Tag = "" Then Exit Sub
  50.     EntObj.GetXData Name, xdType, xdData
  51.     If Not IsEmpty(xdType) Then
  52.         For i = LBound(xdType) To UBound(xdType)
  53.             If xdData(i) <> "" Then
  54.                 temp = Split(xdData(i), "=", , vbTextCompare)
  55.                 If Not IsEmpty(temp) Then
  56.                     If StrComp(temp(0), Tag, vbTextCompare) = 0 Then
  57.                         bExist = True
  58.                         xdData(i) = Tag & "=" & Text
  59.                         EntObj.SetXData xdType, xdData
  60.                         Exit For
  61.                     End If
  62.                 End If
  63.                 temp = Empty
  64.             End If
  65.         Next
  66.         If bExist = False Then
  67.             temp = UBound(xdType) + 1
  68.             ReDim Preserve xdType(0 To temp)
  69.             ReDim Preserve xdData(0 To temp)
  70.             xdType(temp) = 1000
  71.             xdData(temp) = Tag & "=" & Text
  72.             EntObj.SetXData xdType, xdData
  73.             temp = Empty
  74.         End If
  75.     Else
  76.         ReDim xdType(0 To 1) As Integer
  77.         ReDim xdData(0 To 1) As Variant
  78.         xdType(0) = 1001
  79.         xdData(0) = Name
  80.         xdType(1) = 1000
  81.         xdData(1) = Tag & "=" & Text
  82.         EntObj.SetXData xdType, xdData
  83.     End If
  84.     xdType = Empty
  85.     xdData = Empty
  86.     Exit Sub
  87.
  88. ErrTrap:
  89.     Debug.Print "SetXDataText: " & Err.Number & ", " & Err.Description
  90.     On Error GoTo 0
  91. End Sub
  92.   [/FONT]
发表于 2002-11-21 22:22:50 | 显示全部楼层
我正在发愁
split()
编译错误
子程序或函数未定义
已领礼包: 181个
 楼主| 发表于 2002-11-22 08:54:07 | 显示全部楼层
忘了说明,Split只有在VBA6.0以上才有的。可以放在VB中,做一个动态链接库,以后直接调用就可以了。或者用R2002,它的VBA版本是6.0的。
已领礼包: 181个
 楼主| 发表于 2002-11-22 09:00:05 | 显示全部楼层
你可以用VB6.0为R2000版本中所没有的VBA函数做一个库,使用时只要引用就可以了,相当于扩充了CAD中VBA的功能。
附上一些例子。
  2. Public Enum VbTriState
  3.     vbFalse = 0
  4.     vbTrue = -1
  5.     vbUseDefault = -2
  6. End Enum
  7. Public Enum VbCompareMethod
  8.     vbBinaryCompare = 0
  9.     vbDatabaseCompare = 2
  10.     vbTextCompare = 1
  11. End Enum
  12. Public Function VBFilter(ByVal SourceArray As Variant, ByVal Match As String, Optional ByVal Include As Boolean = True, Optional ByVal Compare As VbCompareMethod = vbBinaryCompare)
  13.     VBFilter = ""
  14.     On Error GoTo ErrTrap
  15.     VBFilter = Filter(SourceArray, Match, Include, Compare)
  16.     Exit Function
  17. ErrTrap:
  18.     Debug.Print "VBFilter: " & Err.Number & ", " & Err.Description
  19.     On Error GoTo 0
  20. End Function
  21. Public Function VBFormatCurrency(ByVal Expression As Variant, Optional ByVal NumDigitsAfterDecimal As Long = -1, Optional ByVal IncludeLeadingDigit As VbTriState = vbUseDefault, Optional ByVal UseParensForNegativeNumbers As VbTriState = vbUseDefault, Optional ByVal GroupDigits As VbTriState = vbUseDefault) As String
  22.     VBFormatCurrency = ""
  23.     On Error GoTo ErrTrap
  24.     VBFormatCurrency = FormatCurrency(Expression, NumDigitsAfterDecimal, IncludeLeadingDigit, UseParensForNegativeNumbers, GroupDigits)
  25.     Exit Function
  26. ErrTrap:
  27.     Debug.Print "VBFormatCurrency: " & Err.Number & ", " & Err.Description
  28.     On Error GoTo 0
  29. End Function
  30. Public Function VBFormatDateTime(ByVal Expression As Variant, Optional ByVal NamedFormat As VbDateTimeFormat = vbGeneralDate) As String
  31.     VBFormatDateTime = ""
  32.     On Error GoTo ErrTrap
  33.     VBFormatDateTime = FormatDateTime(Expression, NamedFormat)
  34.     Exit Function
  35. ErrTrap:
  36.     Debug.Print "VBFormatDateTime: " & Err.Number & ", " & Err.Description
  37.     On Error GoTo 0
  38. End Function
  39. Public Function VBFormatNumber(ByVal Expression As Variant, Optional ByVal NumDigitsAfterDecimal As Long = -1, Optional ByVal IncludeLeadingDigit As VbTriState = vbUseDefault, Optional ByVal UseParensForNegativeNumbers As VbTriState = vbUseDefault, Optional ByVal GroupDigits As VbTriState = vbUseDefault) As String
  40.     VBFormatNumber = ""
  41.     On Error GoTo ErrTrap
  42.     VBFormatNumber = FormatNumber(Expression, NumDigitsAfterDecimal, IncludeLeadingDigit, UseParensForNegativeNumbers, GroupDigits)
  43.     Exit Function
  44. ErrTrap:
  45.     Debug.Print "VBFormatNumber: " & Err.Number & ", " & Err.Description
  46.     On Error GoTo 0
  47. End Function
  48. Public Function VBFormatPercent(ByVal Expression As Variant, Optional ByVal NumDigitsAfterDecimal As Long = -1, Optional ByVal IncludeLeadingDigit As VbTriState = vbUseDefault, Optional ByVal UseParensForNegativeNumbers As VbTriState = vbUseDefault, Optional ByVal GroupDigits As VbTriState = vbUseDefault) As String
  49.     VBFormatPercent = ""
  50.     On Error GoTo ErrTrap
  51.     VBFormatPercent = FormatPercent(Expression, NumDigitsAfterDecimal, IncludeLeadingDigit, UseParensForNegativeNumbers, GroupDigits)
  52.     Exit Function
  53. ErrTrap:
  54.     Debug.Print "VBFormatPercent: " & Err.Number & ", " & Err.Description
  55.     On Error GoTo 0
  56. End Function
  57. Public Function VBInStrRev(ByVal StringCheck As String, StringMatch As String, Optional ByVal Start As Long = -1, Optional ByVal Compare As VbCompareMethod = vbBinaryCompare) As Long
  58.     VBInStrRev = ""
  59.     On Error GoTo ErrTrap
  60.     VBInStrRev = InStrRev(StringCheck, StringMatch, Start, Compare)
  61.     Exit Function
  62. ErrTrap:
  63.     Debug.Print "VBInStrRev: " & Err.Number & ", " & Err.Description
  64.     On Error GoTo 0
  65. End Function
  66. Public Function VBJoin(ByVal SourceArray As Variant, Optional ByVal Delimiter As Variant) As String
  67.     VBJoin = ""
  68.     On Error GoTo ErrTrap
  69.     VBJoin = Join(SourceArray, Delimiter)
  70.     Exit Function
  71. ErrTrap:
  72.     Debug.Print "VBJoin: " & Err.Number & ", " & Err.Description
  73.     On Error GoTo 0
  74. End Function
  75. Public Function VBReplace(ByVal Expression As String, ByVal Find As String, ByVal ReplaceWith As String, Optional ByVal Start As Long = 1, Optional ByVal Count As Long = -1, Optional ByVal Compare As VbCompareMethod = vbBinaryCompare) As String
  76.     VBReplace = ""
  77.     On Error GoTo ErrTrap
  78.     VBReplace = Replace(Expression, Find, ReplaceWith, Start, Count, Compare)
  79.     Exit Function
  80. ErrTrap:
  81.     Debug.Print "VBReplace: " & Err.Number & ", " & Err.Description
  82.     On Error GoTo 0
  83. End Function
  84. Public Function VBRound(ByVal Number As Variant, Optional ByVal NumDigitsAfterDecimal As Long)
  85.     VBRound = ""
  86.     On Error GoTo ErrTrap
  87.     VBRound = Round(Number, NumDigitsAfterDecimal)
  88.     Exit Function
  89. ErrTrap:
  90.     Debug.Print "VBRound: " & Err.Number & ", " & Err.Description
  91.     On Error GoTo 0
  92. End Function
  93. Public Function VBSplit(ByVal Expression As String, Optional ByVal Delimiter As Variant, Optional ByVal Limit As Long = -1, Optional ByVal Compare As VbCompareMethod = vbBinaryCompare) As Variant
  94.     VBSplit = Empty
  95.     On Error GoTo ErrTrap
  96.     VBSplit = Split(Expression, Delimiter, Limit, Compare)
  97.     Exit Function
  98. ErrTrap:
  99.     Debug.Print "VBSplit: " & Err.Number & ", " & Err.Description
  100.     On Error GoTo 0
  101. End Function
  102.   [/FONT]
已领礼包: 1261个
发表于 2005-11-26 01:33:50 | 显示全部楼层
谢谢
发表于 2005-11-26 17:34:43 | 显示全部楼层
正需要扩展数据进行操作的函数 。
发表于 2005-12-6 10:45:04 | 显示全部楼层
不知道怎么利用,我有一堆数据是利用扩展数据的
发表于 2005-12-10 12:35:45 | 显示全部楼层
斑竹先生,怎样修改实体上的扩展数据?能给个编程示例吗?
GMT+8, 2026-11-3 17:03 , Processed in 0.536092 second(s), 46 queries , Gzip On.
