查看: 832|回复: 0
[VBA函数]:如何用GetAngle获取缺省角度
发表于 2002-11-14 19:32:09 | 显示全部楼层 |阅读模式
当需要用户按右键指定缺省角度(Degree类型)时,可以用下面的函数。
  1.   [FONT=courier new]
  2. '输入角度
  3. Pt    给定点
  4. Prompt    提示信息
  5. defDeg    缺省角度,不是弧度
  6. Public Function GetAngle(Optional ByVal Pt As Variant, Optional ByVal Prompt As String, Optional ByVal defDeg As Double) As Double
  7.     If defDeg <> 0 Then GetAngle = ThisDrawing.Utility.AngleToReal(CStr(defDeg), acDegrees)
  8.
  9.     On Error GoTo ErrTrap
  10.     If Prompt = "" Then Exit Function
  11.     If Not IsMissing(Pt) Then
  12.        GetAngle = ThisDrawing.Utility.GetAngle(Pt, Prompt)
  13.     Else
  14.        GetAngle = ThisDrawing.Utility.GetAngle(, Prompt)
  15.     End If
  16.     Exit Function
  17.
  18. ErrTrap:
  19.     Debug.Print "GetAngle: " & Err.Number & ", " & Err.Description
  20.     On Error GoTo 0
  21. End Function
  22.   [/FONT]
  2. Sub Test()
  3.     Dim Ang As Double
  4.     Ang = GetAngle(, "请输入角度<" & 45 & ">", 45)
  5.     Debug.Print Ang
  6. End Sub
  7. 当指定角度时,得到45°的弧度值0.785398163397448 。
  8.   [/FONT]
GMT+8, 2026-11-22 11:14 , Processed in 0.589245 second(s), 10 queries , Gzip On, File On.
