查看: 1053|回复: 10
[寻找]:有见过此类问题吗???????
发表于 2004-5-14 19:51:42 | 显示全部楼层 |阅读模式
我作图在模型空间,标柱在图纸空间,如果我完成一张图后,突然要改变比例,怎么才能把图纸空间的标柱跟着我的比例走?
发表于 2004-5-14 20:07:27 | 显示全部楼层
你的问题我都糊涂了,干吗要在图纸空间标注呀,太麻烦了吧
发表于 2004-5-14 20:15:20 | 显示全部楼层
1。别费心了,它本来就跟着比例走的,没有问题的问题。
2。如果不跟着走,说明DIMASSOC≠2,那为什么要把尺寸标在图纸空间?
发表于 2004-5-16 15:23:59 | 显示全部楼层
什么意思?为什么要这么做?
发表于 2004-5-16 15:26:18 | 显示全部楼层
头晕阿,在图纸空间标注的话,那就没有必要用图纸空间了,这么麻烦。
发表于 2004-5-16 15:32:55 | 显示全部楼层
作图在模型空间,标注在图纸空间也可以的,并且图纸空间的视口改变比例时,原来在图纸空间的标注值不变,但由于视口比例改变了,标注们相对的位置会发生变化,将根据物体的缩放而跟随着移动
发表于 2004-5-16 15:37:59 | 显示全部楼层
我明白楼主为什么要标注在图纸空间,虽然字体大小容易控制,但是标注比例不是也要调整的呀!!
一样的,没有办法省事的!
发表于 2004-5-16 19:21:35 | 显示全部楼层
没问题,其实你是在图纸空间的浮动模型空间中标注的,与在模型空间标注效果一样。
发表于 2004-5-16 19:36:33 | 显示全部楼层
在图纸空间标注与“浮动模型空间”(8楼指的是maximize viewport?)是不同的,前者的标注绝对位于图纸空间,后者实际上就是在模型空间的标注
Dimension in model space for plotting in model space. This is the traditional method used with single-view drawings. To create dimensions that are scaled correctly for plotting, set the DIMSCALE system variable to the inverse of the intended plot scale. For example, if the plot scale is 1/4, set DIMSCALE to 4.
Dimension in model space for plotting in paper space. This was the preferred method for complex, multiple-view drawings prior to AutoCAD 2002. Use this method when the dimensions in a drawing need to be referenced by other drawings (xrefs) or when creating isometric dimensions in 3D isometric views. To prevent the dimensions in one layout viewport from being displayed in other layout viewports, create a dimensioning layer for each layout viewport that is frozen in all other layout viewports. To create dimensions that are scaled automatically for display in a paper space layout, set the DIMSCALE system variable to 0.
Dimension in layouts. This is the simplest dimensioning method. Dimensions are created in paper space by selecting model space objects or by specifying object snap locations on model space objects. By default, associativity between paper space dimensions and model space objects is maintained. No additional scaling is required for dimensions created in a paper space layout: DIMLFAC and DIMSCALE do not need to be changed from their default value of 1.0000.
发表于 2004-5-16 20:03:59 | 显示全部楼层
没有办法只有重新标注了
 楼主| 发表于 2004-5-16 20:25:04 | 显示全部楼层
难道你们都不在图纸空间下标注吗?非常省事!不过问题我已经解决了!
在图纸空间下标注,不必在比例改变的情况下放大或缩小字体大小,
而尺寸则可以在Format/dimension style/annotation/units/linear下输入你想要的比例即可!
GMT+8, 2026-11-6 10:00 , Processed in 0.470389 second(s), 52 queries , Gzip On.
