查看: 8470|回复: 26
[每日一码] 删除模型空间所有不在布局VIEWPORT内部的实体
发表于 2017-5-14 22:37:57 | 显示全部楼层 |阅读模式
  1. (defun c:DelObjNotinViewports (/ A ACDOC CEN ENT FFGG LST M N NOR OCS OLDORTHOMODE OLDOSMODE OLDSNAPMODE R S SSDELETE SSET SSETALL SSVP STRMSG V VERTICES VPE VPNM VPT X)
  2.   (vl-load-com)
  3.   ;;----------------------------------------------------------------------;;
  4.   ;;                         Function Definitions                         ;;
  5.   ;;----------------------------------------------------------------------;;
  6.   (defun kdub:ssunion (ss1 ss2 / ss index)
  7.     ;; Union of two selection sets
  8.     ;; Source : http://www.theswamp.org/index.php?topic=46652.0
  9.     (setq ss (ssadd))
  10.     (cond ((and ss1 ss2)
  11.            (setq index -1)
  12.            (repeat (sslength ss1) (ssadd (ssname ss1 (setq index (1+ index))) ss))
  13.            (setq index -1)
  14.            (repeat (sslength ss2) (ssadd (ssname ss2 (setq index (1+ index))) ss))
  15.           )
  16.           (ss1 (setq ss ss1))
  17.           (ss2 (setq ss ss2))
  18.           (t (setq ss nil))
  19.     )
  20.     ss
  21.   )
  22.   ;;
  23.   ;;
  24.   (defun kdub:sssubtract (ss1 ss2 / ss)
  25.     ;; Subtracts one selection set from another and returns their difference
  26.     ;; Source : http://www.theswamp.org/index.php?topic=46652.0
  27.     (cond ((and ss1 ss2) (vl-cmdf "._Select" ss1 "_Remove" ss2 "") (setq ss (ssget "_P")))
  28.           (ss1 (setq ss ss1))
  29.           (t (setq ss nil))
  30.     )
  31.     ss
  32.   )
  33.   ;;
  34.   ;;
  35.   (defun vpo:lwvertices (e)
  36.     (if (setq e (member (assoc 10 e) e))
  37.       (cons (cons (cdr (assoc 10 e)) (assoc 42 e)) (vpo:lwvertices (cdr e)))
  38.     )
  39.   )
  40.   ;;
  41.   ;;
  42.   (defun LM:ssget (msg arg / sel)
  43.     ;; ssget  -  Lee Mac
  44.     ;; A wrapper for the ssget function to permit the use of a custom selection prompt
  45.     ;; msg - [str] selection prompt
  46.     ;; arg - [lst] list of ssget arguments
  47.     (princ msg)
  48.     (setvar 'nomutt 1)
  49.     (setq sel (vl-catch-all-apply 'ssget arg))
  50.     (setvar 'nomutt 0)
  51.     (if (not (vl-catch-all-error-p sel))
  52.       sel
  53.     )
  54.   )
  55.   ;;
  56.   ;;
  57.
  58.   ;;
  59.   ;;
  60.   (defun trp (m)
  61.     ;; Matrix Transpose  -  Doug Wilson
  62.     ;; Args: m - nxn matrix
  63.     (apply 'mapcar (cons 'list m))
  64.   )
  65.   ;;
  66.   ;;
  67.   (defun mxm (m n)
  68.     ;; Matrix x Matrix  -  Vladimir Nesterovsky
  69.     ;; Args: m,n - nxn matrices
  70.     ((lambda (a) (mapcar '(lambda (r) (mxv a r)) m)) (trp n))
  71.   )
  72.   ;;
  73.   ;;
  74.   (defun mxv (m v)
  75.     ;; Matrix x Vector  -  Vladimir Nesterovsky
  76.     ;; Args: m - nxn matrix, v - vector in R^n
  77.     (mapcar '(lambda (r) (apply '+ (mapcar '* r v))) m)
  78.   )
  79.   ;;
  80.   ;;
  81.   (defun vxs (v s)
  82.     ;; Vector x Scalar  -  Lee Mac
  83.     ;; Args: v - vector in R^n, s - real scalar
  84.     (mapcar '(lambda (n) (* n s)) v)
  85.   )
  86.   ;;
  87.   ;;
  88.   (defun LM:startundo (doc)
  89.     ;; Start Undo  -  Lee Mac
  90.     ;; Opens an Undo Group.
  91.     (LM:endundo doc)
  92.     (vla-startundomark doc)
  93.   )
  94.   ;;
  95.   ;;
  96.   (defun LM:endundo (doc)
  97.     ;; End Undo  -  Lee Mac
  98.     ;; Closes an Undo Group.
  99.     (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc))
  100.   )
  101.   ;;
  102.   ;;
  103.   (defun LM:acdoc nil
  104.     ;; Active Document  -  Lee Mac
  105.     ;; Returns the VLA Active Document Object
  106.     (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
  107.     (LM:acdoc)
  108.   )
  109.   ;;
  110.   ;;
  111.   ;;----------------------------------------------------------------------;;
  112.   ;;                         Actual Program Started                       ;;
  113.   ;;----------------------------------------------------------------------;;
  114.   (LM:startundo (LM:acdoc))
  115.   (setq oldsnapmode (getvar "snapmode"))
  116.   (setq oldosmode (getvar "osmode"))
  117.   (setq oldorthomode (getvar "orthomode"))
  118.   (setvar "snapmode" 0)
  119.   (setvar "osmode" 0)
  120.   (setvar "orthomode" 0)
  121.   (setq sset (ssadd))
  122.   (setq acdoc (LM:acdoc))
  123.   (setvar 'ctab "MODEL")
  124.   ;; Zoom Extents is required so that ssget _CP works properly.
  125.   (command "ZOOM" "E")
  126.   (vlax-for vlayout (vla-get-layouts acdoc)
  127.     (vla-put-ActiveLayout acdoc vlayout)
  128.     (setq vpnm (strcase (vla-get-Name vlayout)))
  129.     (if (not (equal vpnm "MODEL"))
  130.       (progn (setq ssvp (ssget "_A" (list (cons 0 "VIEWPORT") (cons 410 vpnm))))
  131.              (repeat (setq n (sslength ssvp))
  132.                (setq vpt (entget (ssname ssvp (setq n (1- n)))))
  133.                (if (setq ent (cdr (assoc 340 vpt)))
  134.                  (setq lst (vpo:lwvertices (entget ent)))
  135.                  (setq cen (mapcar 'list (cdr (assoc 10 vpt)) (list (/ (cdr (assoc 40 vpt)) 2.0) (/ (cdr (assoc 41 vpt)) 2.0)))
  136.                        lst (mapcar '(lambda (a) (cons (mapcar 'apply a cen) '(42 . 0.0))) '((- -) (+ -) (+ +) (- +)))
  137.                  )
  138.                )
  139.                (setq vpe (cdr (assoc -1 vpt))
  140.                      ocs (cdr (assoc 16 vpt))
  141.                )
  142.                (setq vertices (apply 'append
  143.                                      (mapcar '(lambda (x) (setq ffgg (trans (pcs2wcs (car x) vpe) 0 ocs)) (list (list (car ffgg) (cadr ffgg))))
  144.                                              lst
  145.                                      )
  146.                               )
  147.                )
  148.                (setvar 'ctab "MODEL")
  149.                (setq sset (kdub:ssunion sset (ssget "_CP" vertices (list (cons 410 "Model")))))
  150.              )
  151.       )
  152.     )
  153.   )
  154.   (cond (sset
  155.          (setq countsset (sslength sset))
  156.          (setvar 'ctab "MODEL")
  157.          (setq ssetall (ssget "_A" (list (cons 410 "Model"))))
  158.          (cond (ssetall
  159.                 (setq countssetall (sslength ssetall))
  160.                 (setq countdel (- countssetall countsset))
  161.                 (setq strmsg (strcat "Found "
  162.                                      (itoa countsset)
  163.                                      " objects which are part of viewports."
  164.                                      "\nFound "
  165.                                      (itoa countssetall)
  166.                                      " total objects in MODEL."
  167.                                      "\nDeleting "
  168.                                      (itoa countssetall)
  169.                                      " - "
  170.                                      (itoa countsset)
  171.                                      " objects = "
  172.                                      (itoa countdel)
  173.                                      " objects from MODEL.\n"
  174.                              )
  175.                 )
  176.                 (setq ssdelete (kdub:sssubtract ssetall sset))
  177.                 (command "erase" ssdelete "")
  178.                )
  179.                (T (setq strmsg "No objects found in MODEL to be deleted.\n"))
  180.          )
  181.         )
  182.         (T (setq strmsg "No objects found which are present in MODEL and in Viewports.\n"))
  183.   )
  184.   (princ (strcat "\n\n" strmsg "\n\n"))
  185.   (alert strmsg)
  186.   (setvar "snapmode" oldsnapmode)
  187.   (setvar "orthomode" oldorthomode)
  188.   (setvar "osmode" oldosmode)
  189.   (LM:endundo acdoc)
  190.   (princ)
  191. )
  192. ;;----------------------------------------------------------------------;;
  193. (princ (strcat "\n\n\n:: Deletes all Objects which are not in any Viewport in any Layout  "
  194.                "\n:: Thanks to Lee Mac, Gile, Kerry (KDUB),  Vladimir Nesterovsky and Doug Wilson"
  195.                "\n:: Type \"DelObjNotinViewports\" to Invoke ::"
  196.        )
  197. )
  198. (princ)
  199. ;;----------------------------------------------------------------------;;
  200. ;;                             End of File                              ;;
  201. ;;----------------------------------------------------------------------;;
函数PCS2WCS:
游客,如果您要查看本帖隐藏内容请回复
发表于 2017-5-15 05:44:23 | 显示全部楼层
这个标题有点费解呀..
发表于 2017-5-15 08:07:33 | 显示全部楼层
这个好,对图纸交给甲方之前能够用上,谢谢楼主!
发表于 2017-5-15 08:18:02 | 显示全部楼层
图纸空间很多视口范围外的,在模型空间的,这些实体,被删除。
或者说,模型空间里面,没有设置到图纸空间视口内显示的,删除。
发表于 2017-5-15 09:06:42 | 显示全部楼层
感谢楼主分享!!!!!!
发表于 2017-5-15 09:11:33 | 显示全部楼层
感谢分享源码。
发表于 2017-9-27 17:45:14 | 显示全部楼层
xiankankanzaishuo
发表于 2017-9-27 22:39:39 | 显示全部楼层
回复学习学习!
发表于 2017-10-3 16:08:26 | 显示全部楼层
感谢分享。。。。。。
发表于 2017-10-5 00:11:13 | 显示全部楼层
谢谢分享。
发表于 2018-4-12 23:53:08 | 显示全部楼层
下载看看对自己是否有用!
发表于 2018-4-13 09:37:50 | 显示全部楼层
必须要顶你
发表于 2019-1-8 10:13:53 | 显示全部楼层
来学习一下
发表于 2019-1-8 18:36:17 来自手机 | 显示全部楼层
学习一下
来自: 微社区
发表于 2019-1-9 22:16:09 | 显示全部楼层
感谢分享源码。
GMT+8, 2026-11-22 07:47 , Processed in 0.394993 second(s), 37 queries , Gzip On, File On.
