查看: 1055|回复: 6
[求助]:XDRX_API问题
发表于 2002-11-19 15:28:10 | 显示全部楼层 |阅读模式
(xdrx_slide_list "acad") 返回怎么是NIL
已领礼包: 145个
发表于 2002-11-19 15:34:26 | 显示全部楼层
谢谢!,应该是路径太长的问题,下版本修正。
  1. 命令: (xdrx_slide_list "acad.slb")
  2. nil
  3. 命令: !xdrx_slide_list
  4. #<SUBR @01ff244c <EXRXSUBR>>
  5. 命令: (findfile "acad.slb")
  6. [color=blue]"E:\\Program Files\\LiZheng\\LAr2002\\sys\\acad.slb"[/color]
  7. 在C盘上,就正确。
  8. 命令: (xdrx_slide_list "c:\\acad.slb")
  9. ("ZIGZAG" "WEDGEPIC" "WEDGE" "VPORT-4R" "VPORT-4L" "VPORT-4" "VPORT-3V"
  10. "VPORT-3R" "VPORT-3L" "VPORT-3H" "VPORT-3B" "VPORT-3A" "VPORT-2V" "VPORT-2H"
  11. "VPORT-1" "VP-UR" "VP-UL" "VP-U" "VP-RIGHT" "VP-PLAN" "VP-LR" "VP-LO" "VP-LL"
  12. "VP-LEFT" "U-WORLD" "U-TOP" "U-RIGHT" "U-PREV" "U-LEFT" "U-FRONT" "U-CVIEW"
  13. "U-BOTTOM" "U-BACK" "TRIANG" "TRANS" "TORUS" "TORPIC" "SWAMP" "STEEL" "STARS"
  14. "SQUARE" "SPHERPIC" "SPHERE" "SOLID" "SACNCR" "PYRAMID" "PT100" "PT99" "PT98"
  15. "PT97" "PT96" "PT68" "PT67" "PT66" "PT65" "PT64" "PT36" "PT35" "PT34" "PT33"
  16. "PT32" "PT4" "PT3" "PT2" "PT1" "PT0" "PM-QUAD" "PM-CUBIC" "PM-BEZR" "PLASTI"
  17. "PLAST" "PL-QUAD" "PL-CUBIC" "NET3" "NET" "MUDST" "MESH" "MEDIT_WA" "MEDIT_OT"
  18. "MEDIT_OC" "MEDIT_MT" "MEDIT_MC" "MEDIT_DV" "MEDIT_CT" "MEDIT_CS" "MEDIT_CJ"
  19. "MEDIT_CC" "MEDIT_CA" "MEDIT_AV" "LINE" "INSUL" "HOUND" "HONEY" "HEX" "H-OUTER"
  20. "H-NORMAL" "H-IGNORE" "GRATE" "GRASS" "GDTU" "GDTT" "GDTS" "GDTR" "GDTP" "GDTN"
  21. "GDTM" "GDTL" "GDTK" "GDTJ" "GDTI" "GDTH" "GDTG" "GDTF" "GDTE" "GDTD" "GDTC"
  22. "GDTB" "GDTA" "FLEX" "ESCHER" "EARTH" "DOTS" "DOME" "DOLMIT" "DISH" "DDVP3D"
  23. "DASH" "CYLPIC" "CROSS" "CORK" "CONEPIC" "CONE" "CLAY" "CHROMA" "BRSTONE"
  24. "BRICK" "BRASS" "BOXPIC" "BOX3D" "BOX" "AR-SAND" "AR-RSHKE" "AR-RROOF"
  25. "AR-PARQ1" "AR-HBONE" "AR-CONC" "AR-BRSTD" "AR-BRELM" "AR-B88" "AR-B816C"
  26. "AR-B816" "ANSI38" "ANSI37" "ANSI36" "ANSI35" "ANSI34" "ANSI33" "ANSI32"
  27. "ANSI31" "ANGLE" "AILOGO" "15W100" "14W100" "13W100" "12W100" "11W100" "10W100"
  28. "09W100" "08W100" "07W100" "06W100" "05W100" "04W100" "03W100" "02W100"
  29. "%%BLANK")
复制代码
 楼主| 发表于 2002-11-19 15:44:53 | 显示全部楼层
为什么运行slbmagic后,就可以
已领礼包: 145个
发表于 2002-11-19 15:49:43 | 显示全部楼层
最初由 hqd9639 发布
[B]为什么运行slbmagic后,就可以 [/B]
你用 (findfile "acad.slb") 看看前后的两个ACAD.SLB是不是同一个文件?
我需要看代码,解决。
 楼主| 发表于 2002-11-19 15:54:59 | 显示全部楼层
用在这里:
(defun showslb ()
  (Slblist)
  (setq nnCount (Odcl_Tree_CountItems ACADVIEW_DclForm6_TreeControl1))
  (Odcl_Tree_Clear ACADVIEW_DclForm6_TreeControl1)
  (if (= nnCount 0)
      (progn
          (Odcl_Tree_AddParent ACADVIEW_DclForm6_TreeControl1 "slide" "t1")
          (Odcl_Tree_AddParent ACADVIEW_DclForm6_TreeControl1 "slide1" "t3")
          (Odcl_Tree_AddParent ACADVIEW_DclForm6_TreeControl1 "acad" "t2")
          (Odcl_Tree_AddChild ACADVIEW_DclForm6_TreeControl1 slb_sldlst)
(defun Slblist ()
    (setq slb_sldlst '())
    (setq mm 1)
    (setq slb_sld (xdrx_slide_list "acad"))
    (foreach n slb_sld
       (setq slb_sldlst1 (list (list "t2" n (strcat "C" (itoa mm)))))
       (setq slb_sldlst (append slb_sldlst slb_sldlst1))
       (setq mm (1+ mm))
已领礼包: 145个
发表于 2002-11-19 15:58:31 | 显示全部楼层
你用 (findfile "acad.slb") 看看用SLIBMAGIC前后的两个ACAD.SLB是不是同一个文件?
 楼主| 发表于 2002-11-19 16:11:00 | 显示全部楼层
一样的
GMT+8, 2026-11-3 01:32 , Processed in 0.556260 second(s), 45 queries , Gzip On.
