查看: 1196|回复: 0
[下载]:Verify on Save v1.0 Beta from Discreet
发表于 2002-11-19 16:50:01 | 显示全部楼层 |阅读模式
09.11.2002 - R4 R5
New Plugin: Global Utilities
Verify on Save v1.0 Beta from Discreet.
This plugin is designed to detect corrupt 3ds max files at the time they are saved. Under normal conditions, you should not notice any changes to 3ds max. However if the plugin detects a corrupted max file has been saved, you will be notified with an error message prompting you to resave the file. At that point, try and see if you can Save As as different file. NOTE: This plugin does not check autobak files.
This plugin is currently beta. Use at your own risk. We are not aware of any problems at this time. If you should run in to any problems, please report them.
http://www.maxplugins.de/r5_files/discreet/Verify_on_Save.zip
GMT+8, 2026-11-3 07:06 , Processed in 0.487781 second(s), 32 queries , Gzip On.
