查看: 1152|回复: 3
[ARX程序]:碰到奇怪的问题,一直没有解决!大家帮个忙。
发表于 2004-5-21 18:05:34 | 显示全部楼层 |阅读模式
Adesk::Boolean getModelSpaceRecord(AcDbBlockTableRecord*& pBlkTableRecord);
Adesk::Boolean g_bProceed = Adesk::kFalse;
void drawWindo()
        AcDbBlockTableRecord* pBlkTableRecord;
        RectWindow *pRectWindow;
        RectWindow *pGenericWind;
if(g_bProceed)
        pRectWindow = new RectWindow;
                pGenericWind = pRectWindow;
                pGenericWind->setWindowLength(windInfo.m_dWindWt);
                pGenericWind->setWindowHeight(windInfo.m_dWindHt);
                pGenericWind->setWindowCols(windInfo.m_nCols);
                pGenericWind->setWindowRows(windInfo.m_nRows);
                pGenericWind->setWindowStartPoint(windInfo.m_startPt);
//acutPrintf("g_pWindoTypeDlg->m_dHeight");
//AfxMessageBox("g_pWindoTypeDlg->m_dHeight");
        if(!getModelSpaceRecord(pBlkTableRecord))
                        return;
                pGenericWind->drawWindow(pBlkTableRecord);
                if(pGenericWind != NULL)
                        delete pGenericWind;
                pBlkTableRecord->close();
}// if g_bProceed
        else
                acutPrintf("\nUser cancelled. ");
        AcDbDatabase *pCurDb;
        AcDbBlockTable *pBlkTable;
        Acad::ErrorStatus es;
        pCurDb = acdbHostApplicationServices()->workingDatabase();
        es = pCurDb->getBlockTable(pBlkTable, AcDb::kForRead);
        if(es != Acad::eOk)
                acutPrintf("\nFailed to open Block Table for a read operation.");
                return Adesk::kFalse;
        es = pBlkTable->getAt(ACDB_MODEL_SPACE, pBlkTableRecord, AcDb::kForWrite);
        if(es != Acad::eOk)
                acutPrintf("\nFailed to open MODEL SPACE for a write operation.");
                pBlkTable->close();
                pBlkTable->close();
        return Adesk::kTrue;
编译通过在运行的时候 一直是显示的User cancelled!
原因可能是不能open MODEL SPACE for a write operation。。
是不是在哪里应该添加一句pBlkTableRecord->close() ??
大家帮忙指点看一下
另外在调试的时候我想在CAD里面查询赋值,
为什么都得不到 对话框中的参数?
发表于 2004-5-21 22:06:49 | 显示全部楼层
1)
May be your program  has never set global  variable  g_bProceed  to value Adesk::kTrue.
2)
acutPrintf("g_pWindoTypeDlg->m_dHeight");  ==> Correct as follow:
acutPrintf("g_pWindoTypeDlg->m_dHeight= %ld[/COLOR]\n",   g_pWindoTypeDlg->m_dHeight);
   // if the type of m_dHeight is long;  or
acutPrintf("g_pWindoTypeDlg->m_dHeight= %lf[/COLOR]\n",   g_pWindoTypeDlg->m_dHeight);
    // if the type of m_dHeight is ads_real
 楼主| 发表于 2004-5-22 00:09:01 | 显示全部楼层
[QUOTE]最初由 ishou 发布
[B]1)
ishuo首先谢谢你
不知道global  variable  具体在哪里设定  我在上面已经声明了
发表于 2004-5-23 15:06:24 | 显示全部楼层
你的这个声明/设定:Adesk::Boolean g_bProceed = Adesk::kFalse[/COLOR];
是表示不执行 下面的 Express_A,而是执行 Express_B.
  1. if(g_bProceed)
  2. {
  3.     Express_A;
  4. } else {
  5.     Express_B;
  6. }
复制代码
如果要执行 Express_A, 你必须设置如下:
g_bProceed = Adesk::kTrue[/COLOR];
显然这里的 全局变量g_bProceed 的状态 (kTrue/kFalse) 是用于控制函数 drawWindo()是否去实质
实施“绘图"之类的操作。
"不知道global variable 具体在哪里设定 "? [/COLOR] ===>
在调用DrawWindo() 时,你必须明确g_bProceed 的状态 :kTrue 还是kFalse. 因此,在调用
DrawWind()之前,你必须设定g_bProceed 的值。如果不设定,那么g_bProcess的值(状态)就
是你在声明g_bProcess时的值 (kFalse).
GMT+8, 2026-11-2 16:42 , Processed in 0.693898 second(s), 38 queries , Gzip On.
