查看: 1111|回复: 4
[ARX程序]:编译成功,运行时一直不能打开MODEL SPACE?请问哪里出错?
发表于 2004-5-16 02:14:42 | 显示全部楼层 |阅读模式
Failed to open MODEL SPACE for a write operation。
void drawWin()
        AcDbBlockTableRecord *pBlkTableRecord;
        RectWindow *pRectWindow;        // RectWindow class
        RectWindow *pGenericWind;
                acedInitGet(NULL, "Arch apeX Rect");
                         pRectWindow = new RectWindow;
                        pGenericWind = pRectWindow;
                        if(!getModelSpaceRecord(pBlkTableRecord))
                                return;
                        pRectWindow->drawWindow(pBlkTableRecord);
                pGenericWind->setWindowLength(windInfo.m_dWindWt);
                pGenericWind->setWindowHeight(windInfo.m_dWindHt);
                pGenericWind->setWindowCols(windInfo.m_nCols);
                pGenericWind->setWindowRows(windInfo.m_nRows);
                pGenericWind->setWindowStartPoint(windInfo.m_startPt);
                        return;
                pGenericWind->drawWindow(pBlkTableRecord);
                if(pGenericWind != NULL)
                        delete pGenericWind;
                pBlkTableRecord->close();
                // variables.
//                g_bProceed = Adesk::kFalse;
}// if g_bProceed;
/*        else
                acutPrintf("\nUser cancelled. ");
Adesk::Boolean getModelSpaceRecord(AcDbBlockTableRecord*& pBlkTableRecord)
        AcDbDatabase *pCurDb;
        AcDbBlockTable *pBlkTable;
        Acad::ErrorStatus es;
        pCurDb = acdbHostApplicationServices()->workingDatabase();
        es = pCurDb->getBlockTable(pBlkTable, AcDb::kForRead);
        if(es != Acad::eOk)
                acutPrintf("\nFailed to open Block Table for a read operation.");
                return Adesk::kFalse;
        es = pBlkTable->getAt(ACDB_MODEL_SPACE, pBlkTableRecord, AcDb::kForWrite);
        if(es != Acad::eOk)
                acutPrintf("\nFailed to open MODEL SPACE for a write operation.");
                pBlkTable->close();
        pBlkTable->close();
        return Adesk::kTrue;
发表于 2004-5-16 21:23:30 | 显示全部楼层
You open  pBlkTableRecord  under AcDb::kForWrite  for many times and
not to  use  ->close()  before the next  open,  when you call
GetModelSpaceRecord(pBlkTableRecord) for many times.
  1. void drawWin()
  2. {
  3. AcDbBlockTableRecord *pBlkTableRecord;
  4. RectWindow *pRectWindow; // RectWindow class
  5. RectWindow *pGenericWind;
  6. acedInitGet(NULL, "Arch apeX Rect");
  7. pRectWindow = new RectWindow;
  8. pGenericWind = pRectWindow;
  9. [COLOR=Blue]/*   [/COLOR][COLOR=Red]    <<---------why? where is the match */  ?   [/COLOR]
  10. AcDbBlockTableRecord *pBlkTableRecord;
  11. if(!getModelSpaceRecord(pBlkTableRecord))
  12. {
  13. return;
  14. }
  15. pRectWindow->drawWindow(pBlkTableRecord);
  16. pGenericWind->setWindowLength(windInfo.m_dWindWt);
  17. pGenericWind->setWindowHeight(windInfo.m_dWindHt);
  18. pGenericWind->setWindowCols(windInfo.m_nCols);
  19. pGenericWind->setWindowRows(windInfo.m_nRows);
  20. pGenericWind->setWindowStartPoint(windInfo.m_startPt);
  21. if(!getModelSpaceRecord(pBlkTableRecord))
  22. {
  23. return;
  24. }
  25. pGenericWind->drawWindow(pBlkTableRecord);
  26. if(pGenericWind != NULL)
  27. {
  28. delete pGenericWind;
  29. }
  30. pBlkTableRecord->close();
  31. // variables.
  32. // g_bProceed = Adesk::kFalse;
  33. }// if g_bProceed;
  34. /* else
  35. {
  36. acutPrintf("\nUser cancelled. ");
  37. }*/
  38. Adesk::Boolean getModelSpaceRecord(AcDbBlockTableRecord*& pBlkTableRecord)
  39. {
  40. AcDbDatabase *pCurDb;
  41. AcDbBlockTable *pBlkTable;
  42. Acad::ErrorStatus es;
  43. pCurDb = acdbHostApplicationServices()->workingDatabase();
  44. es = pCurDb->getBlockTable(pBlkTable, AcDb::kForRead);
  45. if(es != Acad::eOk)
  46. {
  47. acutPrintf("\nFailed to open Block Table for a read operation.");
  48. return Adesk::kFalse;
  49. }
  50. es = pBlkTable->getAt(ACDB_MODEL_SPACE, pBlkTableRecord, AcDb::kForWrite);
  51. if(es != Acad::eOk)
  52. {
  53. acutPrintf("\nFailed to open MODEL SPACE for a write operation.");
  54. pBlkTable->close();
  55. return Adesk::kFalse;
  56. }
  57. pBlkTable->close();
  58. return Adesk::kTrue;
  59. }
复制代码
 楼主| 发表于 2004-5-17 07:59:32 | 显示全部楼层
/*不小心打上去的 ,请问具体怎么改?
发表于 2004-5-17 20:53:37 | 显示全部楼层
You have to do  pBlkTableRecord->close()  at several places.
It is easy!
You try by yourself!
Wish you success!
 楼主| 发表于 2004-5-18 20:19:01 | 显示全部楼层
我重新又改了几次 ,还是不能 open MODEL SPACE
有谁碰倒过 这种问题??
帮解释一下。
GMT+8, 2026-11-22 10:42 , Processed in 0.303671 second(s), 18 queries , Gzip On, File On.
