查看: 1057|回复: 1
[求助]:块引用问题
发表于 2003-10-24 19:03:17 | 显示全部楼层 |阅读模式
以下一段程序应该没问题,我也用block命令做了块gc1234,可为什么却提示:Block definition gc1234 not found,怎么回事呢?
void insrtBlk()
        char blkName[50];
        AcDbDatabase *pCurDb;
        AcDbBlockTable *pBlkTable;
        AcDbBlockTableRecord *pBlkTableRecord;
        AcDbBlockReference *pInsrtObj;
        AcDbObjectId blkId;
        AcGePoint3d insPt;
        int retCode;
        retCode = acedGetString(0, "\nEnter Block Name: ", blkName);
        if(retCode != RTNORM || blkName[0] == '\0')
                acutPrintf("\nInvalid block name.");
                return;
        pCurDb = acdbHostApplicationServices()->workingDatabase();
        // Check to see if the block table
        // has blkName
        pCurDb->getBlockTable(pBlkTable, AcDb::kForRead);
        if(!pBlkTable->has(blkName))
                acutPrintf("\nBlock definition %s not found. ", blkName);
                pBlkTable->close();
                return;
        // Get the AcDbObjectId of the block
        // definition.
        pBlkTable->getAt(blkName, blkId);
        pBlkTable->getAt(ACDB_MODEL_SPACE, pBlkTableRecord, AcDb::kForWrite);
        pBlkTable->close();
        acedInitGet(RSG_NONULL, NULL);
        acedGetPoint(NULL, "\nPick insertion point: ", asDblArray(insPt));
        pInsrtObj = new AcDbBlockReference(insPt, blkId);
        // Here is where you can set scale, rotation and other
        // properties to the block entity. If you want to
        // see the AcDbBlockReference class for more details.
        pBlkTableRecord->appendAcDbEntity(blkId, pInsrtObj);
        pBlkTableRecord->close();
        pInsrtObj->close();
发表于 2003-10-27 16:17:19 | 显示全部楼层
我是这样作的。
          AcDbObjectId blockId;
           //blkName 是快名
        pBlockTable->getAt(blkName,blockId,false);
        pBlockTable->close();
                     if(blockId==NULL)
return;
剩下的和你一样。
GMT+8, 2026-11-2 22:13 , Processed in 0.539657 second(s), 34 queries , Gzip On.
