楼主: wowoaicad
[推荐]:Excel文件连接工具Excellink 2000
 楼主| 发表于 2002-11-28 16:28:37 | 显示全部楼层
使用前,请看看excellink2000帮助。
两个版本旧为15.0.12.10341;新的为15.0.21.20916。
建议先阅读其帮助后,了解清楚后再决定是否下载安装。新的为15.0.21.20916的演示见http://www.xdcad.net/forum/showt ... tid=96089#post96089
 楼主| 发表于 2002-11-28 17:02:13 | 显示全部楼层
这还有一个老版本,使用前,请看看。
1.版本为15.0.12.10341,建议先阅读其帮助后,了解清楚后再决定是否安装。
2.未注册为演示版本,且功能受限制很多,观察到如下几点:
在输出图块属性后,有时选项和帮助窗口打不开,表现为出现AutoCAD2002选项
和帮助。
点击次数超过?次后功能消失,只出现要求打开的.wmf文件窗口。
软件卸载不彻底,卸载并清理注册表后,依然残留软件信息,需人工删除。
3.需要者请到excellink发布网站看看。
最新版本更新情况:
What's new ?
What's new in this version ?
Version number List of updates
15.0.21.20916 Added support for AutoCAD LT 2002 SP2. New block selection options (in block selection dialog, press right mouse button).
15.0.20.20829 Fixed some problems with LT integration.
15.0.19.12108 Added support for AutoCAD LT 2002.
15.0.18.12097 Fixed small problems with unloading application. Updated license mechanism. New installer (MSI).
15.0.17.12044 Fixed problem when importing rotation angles. Added small tutorial. Excellink goes to be multilingual - there is French version available (thanks to Nils Degremont for assistance).
15.0.16.11232 Fixed problem with importing of rows, which have first cell empty.
15.0.15.11201 Fixed problem with COM Error: Invalid index while importing sheet content into AutoCAD.
15.0.14.11157 Product is now split to ARX and resource module (for localization purposes).
Small fixes in LT loader.
15.0.13.11004 Added option to save/restore configration from cfg file. Export function can automatically find next blank line, when exporting all blocks into single sheet. Added partial support (no dialogs, only cmd line) for using of application within scripts.
15.0.12.10341 Added option Force cell format to text, which control output format of cells.
15.0.11.10336 Correctly handles empty attribute values, when importing.
15.0.10.10315 When multiple blocks are imported from one sheet, it correctly handles items without comments.
15.0.9.10258 Solved problem with non-administrator accounts.
15.0.8.10240 Added support for AutoCAD LT 2000i.
15.0.7.10217 Added possibility to export coordinates in JTSK form (used in GIS applications).
Added possibility to leave current column width.
Cancel button in register dialog was changed to 'Continue as trial'.
15.0.6.10174 Added possibility to export X, Y, Z coordinates individually.
Added possibility to export layout name.
Added possibility to export data on odd lines.
15.0.5.10117 Solved problem with conversion between string and real number, which causes problem when importing geometric properties (i.e. coordinates).
Added new option Toolbar.
15.0.4.10115 Solved problem with resource handling, which occures, when Properties window is active.
LTstart.exe loads menu file before AutoCAD LT starts.
15.0.3.10111 Application now supports AutoCAD LT 2000.
Installer was updated.
Export of block name is optional.
Values are sorted according to corresponding attribute names.
About tab displays build number.
15.0.2.10109 Application now allows export blocks without attributes.
Block name is also exported.
Both model and paper space entities are processed.
15.0.1.10098 Application now allows export constant attributes.
15.0.0.10080 Application now correctly releases connection to Excel.
When One sheet option is used for export header row is added for each block.
Setup supports Excel 2000.
15.0.0.10069 New version for AutoCAD 2000 (based on Excellink LT)
Supports data import from Microsoft Excel sheets
Dynamic link of Excel changes to a drawing
Updated: 16.09.2002
Copyright ?2000-2002 CAD Studio s.r.o.
发表于 2002-11-28 20:16:24 | 显示全部楼层
wowoaicad:请说说Excellink对AutoCAD、Excel有何要求,如VBA支持等等,即谈谈ACAD安装有没有专门要求等
 楼主| 发表于 2002-11-28 22:37:34 | 显示全部楼层
请蓝猫看看附件,安装监视记录。
自制的图块的excellink2000演示过程:
GMT+8, 2026-11-3 07:33 , Processed in 0.503667 second(s), 32 queries , Gzip On.
