查看: 786|回复: 3
[求助]:如何使用程序卸载一个已经加载的.ARX程序?
发表于 2004-5-29 13:46:57 | 显示全部楼层 |阅读模式
刚刚学习ObjectARX编程,遇到一个问题“如何卸载一个已经加载的.ARX程序?”
我想解决的方法有三种:
一、在AutoCAD中调用Appload命令卸载已经加载的程序;
二、使用所加载程序中自身的卸载命令;
三、调用第三个程序中的命令(专用卸载命令)卸载已加载的程序。
但是我自己对ObjectARX了解不多,没办法实现后两个方法,请哪位大哥不吝赐教。
已领礼包: 13个
发表于 2004-5-31 00:18:09 | 显示全部楼层
Re: [求助]:如何使用程序卸载一个已经加载的.ARX程序?
最初由 robot 发布
[B]刚刚学习ObjectARX编程,遇到一个问题“如何卸载一个已经加载的.ARX程序?”
我想解决的方法有三种:
二、使用所加载程序中自身的卸载命令;
三、调用第三个... [/B]
使用:
[php]
AcRxDynamicLinker::unloadApp Function virtual bool
unloadApp(
const char * appName,
bool asCmd = false) = 0;
appName Input null-terminated string which is the application name (as
set in the system registry) of the ObjectARX module to unload
asCmd Input Boolean indicating whether to unload the application as if by
user command
This function unloads the appName ObjectARX program. appName is the
application name as set in the operating system registry. If the ObjectARX
application was not loaded via the AcRxDynamicLinker::loadApp() or
acrxLoadApp() methods or through the demand loading mechanism (all of
which use the system registry entry for the application), then this function
will be unable to unload the application.
When asCmd is kFalse, it's possible to call this method more than once
and still get a successful return value. This method will simply decrement
the reference count for the application.
Note The asCmd value used for unloadApp() must be the same as the
one used for loadApp().
The function returns true if the module was successfully unloaded;
otherwise, it returns false.
[/php]
[php]
AcRxDynamicLinker::unloadModule Function virtual bool
unloadModule(
const char* fileName,
fileName Input null-terminated string which is the file name of the program
to unload
user command
This function unloads the ObjectARX module filename. Before physically
unloading the module, the application's acrxEntryPoint() function is called
with the kUnloadAppMsg message to allow it to perform cleanup.
Notification is also sent about the impending unload.
Note The fileName string is case and path sensitive, so it must be either
exactly the same as string that was used to load the application or it must
be the same as the string returned by the ads_arxloaded() function.
Note The asCmd value used for unloadModule() must be the same as the
one used for loadModule().
[/php]
发表于 2004-5-31 09:11:40 | 显示全部楼层
if (!acrxLoadModule("test.dbx", false))
                        return AcRx::kRetError;
acrxUnloadModule("test.dbx");
 楼主| 发表于 2004-6-1 17:48:11 | 显示全部楼层
谢谢了,我自己这两天也找了一下。好像下面这段也行,请大家指点指点
void vcunload()
        // TODO: Implement the command
        char* ads_appname="abc.arx";
        struct resbuf *rb1, *rb2;
        for (rb2 = rb1 = acedArxLoaded(); rb2 != NULL; rb2 = rb2->rbnext)
                if (rb2->restype == RTSTR)
                        acutPrintf("%s\n", rb2->resval.rstring);
        }acutRelRb(rb1);
                if (strcmp(ads_appname, rb2->resval.rstring) != 0)
                        acedArxUnload(rb2->resval.rstring);
        }acutRelRb(rb1);
GMT+8, 2026-11-5 14:44 , Processed in 0.550228 second(s), 38 queries , Gzip On.
