查看: 888|回复: 0
[日积月累]:读取选择集!
发表于 2002-11-26 16:09:46 | 显示全部楼层 |阅读模式
选择集中的图元读取例子:
注意:读取后其,本身有的属性和方法都可用
程序不一定自己响应,要自己输入
看一下版主的有关 Variant的讨论!
Sub Example_Item()
    ' This example show two uses of the Item method.
    ' The first uses Item with an index counter to return an item in a collection.
    ' The second uses Item with a string to return an item in a collection.
    ' Iterate thru the model space collection,
    ' get all the items in the collection
    ' and store them in an array called newObjs
    Dim count As Integer
    count = ThisDrawing.ModelSpace.count
    ReDim newObjs(count) As AcadEntity
    Dim index As Integer
    For index = 0 To count - 1
        Set newObjs(index) = ThisDrawing.ModelSpace.Item(index)
    Next
    ' Get a particular item, in this case a layer, based on name "0"
    Dim layerObj As AcadLayer
    Set layerObj = ThisDrawing.Layers.Item("0")
End Sub
GMT+8, 2026-11-2 21:43 , Processed in 0.363073 second(s), 32 queries , Gzip On.
