查看: 638|回复: 2
[ARX函数]:{help}:怎样将一个AcDbObject转成AcDb3dSolid类型?
发表于 2004-6-5 10:32:04 | 显示全部楼层 |阅读模式
我在Arx复制一个AcDb3dSolid,返回Id后,用GetObject()得到一个
AcDbObject指针,可是我还准备用来进行bool运算呢?
发表于 2004-6-5 21:46:18 | 显示全部楼层
在Arx复制一个AcDb3dSolid,返回Id后,用GetObject()得到一个AcDbObject指针 pObj[/COLOR],
then:
  1. AcDb3dSolid   *pSolid;
  2. pSolid = AcDb3dSolid[COLOR=Blue]::cast[/COLOR]([COLOR=Red]pObj[/COLOR]);
  3. if (pSolid != NULL) {
  4.     .......// now the  pSolid is your request!
  5. }
复制代码
If you can be sure pObj  is just from ID of AcDb3dSolid , you can do directly as follow:
  2. pSolid = (AcDb3dSolid *) [COLOR=Red]pObj[/COLOR];
复制代码
Ref. to  the section of 'Runtime Class Identification'[/COLOR] in  ObjectARX Developer's Guide (file: arxdoc.chm)
 楼主| 发表于 2004-6-6 21:05:08 | 显示全部楼层
希望下次再有机会交流。
GMT+8, 2026-11-5 22:54 , Processed in 0.541658 second(s), 36 queries , Gzip On.
