查看: 766|回复: 1
[文章]:Selecting file with stardard AutoCAD dialog
发表于 2004-6-10 01:24:35 | 显示全部楼层 |阅读模式
Selecting file with stardard AutoCAD file/open dialog
ID    42014
Applies to:    AutoCAD 2000
Date    5/8/2000
This document is part of   COM-ActiveX Interfaces   Opening Drawings   VBA
Question
Can I gain access to the "Open File Dialog" (with preview) found only in AutoCAD
with VBA?
Answer
There is no explicit API to do this VBA. However, you can do this through the
communication interface with AutoLISP and AutoCAD. The AutoLISP function,
getfiled, behaves as the AutoCAD "Open File Dialog" and allows .DWG files to be
previewed.
The attached VBA code shows how to do it. Here's an overview:
1. Using the SendCommand method, send getfiled AutoLISP expressions to the
AutoCAD command line.
2.  Set the return value to a user-defined system variable USERS1.
3. Use the GetVariable method to retrieve this system variable to store the
selected file name. 4. Use the file name in your VBA code as other variables.
Public Sub OpenDialog()
   Dim fileName As String
   ThisDrawing.SendCommand "(setvar " & """users1""" & "(getfiled " & """Select
a DWG File""" & """c:/program files/acad2000/""" & """dwg""" & "8)) "
   fileName = ThisDrawing.GetVariable("users1")
   MsgBox "You have selected " & fileName & "!!!", , "File Message"
End Sub
发表于 2004-6-10 13:19:58 | 显示全部楼层
不怎么样。
GMT+8, 2026-11-3 06:07 , Processed in 0.496813 second(s), 34 queries , Gzip On.
