查看: 700|回复: 1
[其他]:请问关于arx里BHatch怎么用,谢谢
发表于 2004-6-11 15:25:58 | 显示全部楼层 |阅读模式
在autocad里的操作是这样的:
BHatch命令后,在对话框中,类型选择用户定义,角度**,间距**,点击拾取点,然后确定.
这样的过程在arx程序里面怎么实现?
谢谢
发表于 2004-6-11 19:15:28 | 显示全部楼层
  1.   [FONT=courier new]
  2. Acad::ErrorStatus acqHatch1()
  3. {
  4.     AcDbHatch* pHatch = new AcDbHatch();
  5.     // Set hatch plane
  6.     //
  7.     AcGeVector3d normal(0.0, 0.0, 1.0);
  8.     pHatch->setNormal(normal);
  9.     pHatch->setElevation(0.0);
  10.     // Set non associative hatch
  11.     //
  12.     pHatch->setAssociative(Adesk::kFalse);
  13.     // Set hatch pattern to SolidFill type
  14.     //
  15.     pHatch->setPattern(AcDbHatch::kPreDefined, "SOLID");
  16.     // Set hatch style to kNormal
  17.     //
  18.     pHatch->setStyle(AcDbHatch::kNormal);
  19.     // Construct hatch external boundary
  20.     //
  21.     AcGePoint2dArray vertexPts;
  22.     AcGeDoubleArray vertexBulges;
  23.     vertexPts.setPhysicalLength(0).setLogicalLength(5);
  24.     vertexPts[0].set(2.0, 2.0);
  25.     vertexPts[1].set(8.0, 2.0);
  26.     vertexPts[2].set(8.0, 8.0);
  27.     vertexPts[3].set(2.0, 8.0);
  28.     vertexPts[4].set(2.0, 2.0);
  29.     vertexBulges.setPhysicalLength(0).setLogicalLength(5);
  30.     for (int i = 0; i < 5, i++)
  31.         vertexBulges[i] = 0.0;
  32.     // Append an external loop (rectangle) to hatch boundary
  33.
  34.     pHatch->appendLoop(AcDbHatch::kExternal, vertexPts, vertexBulges);
  35.     // Construct a circle
  36.     //
  37.     AcGePoint2d cenPt(5.0, 5.0);
  38.     double TWOPI = 2.0 * 3.1415926535897932;
  39.     AcGeCircArc2d *cirArc = new AcGeCircArc2d();
  40.     cirArc->setCenter(cenPt);
  41.     cirArc->setRadius(1.0);
  42.     cirArc->setAngles(0.0, TWOPI);
  43.     // Append an internal circular loop to hatch boundary
  44.     //
  45.     AcGeIntArray edgeTypes;
  46.     AcGeVoidPointerArray edgePtrs;
  47.     edgeTypes.append(AcDbHatch::kCirArc);
  48.     edgePtrs.append((void*)cirArc);
  49.     pHatch->appendLoop(AcDbHatch::kDefault, edgePtrs, edgeTypes);
  50.
  51.     // Elaborate solid fill
  52.     //
  53.     pHatch->evaluateHatch();
  54.     // Post hatch entity to database
  55.     //
  56.     pHatch->postToDb(pHatch);
  57.     return eOk;
  58. }
  59.   [/FONT]
复制代码
GMT+8, 2026-11-6 02:39 , Processed in 0.446731 second(s), 34 queries , Gzip On.
