查看: 1044|回复: 5
[下载]:Bentley Explorer 2004 Edition LIC
发表于 2004-6-13 08:50:55 | 显示全部楼层 |阅读模式
Bentley Explorer 2004  Edition LIC,下载!
发表于 2004-6-14 15:22:29 | 显示全部楼层
帮忙一下,谢谢,我的 爱心币不够,请发到我的 邮箱xyw1981@hotmail.com
发表于 2004-8-7 14:48:52 | 显示全部楼层
那里有explore 2004下载阿?
发表于 2004-8-7 17:20:43 | 显示全部楼层
笨了我, 我已经有的, 居然又花一块钱~~~ ^_^ 就当是支援楼主吧~ 然后发张帖子把钱挣回来. ^_^
Explorer 2004 下载地址:
ftp://ftp2.bentley.com/dist/sele ... n/exp08050008en.exe
发表于 2004-8-8 09:11:59 | 显示全部楼层
这个是做什么用的,
不要见怪我是初次接触这个板块
发表于 2004-8-9 08:20:40 | 显示全部楼层
這是我在官網找到的說明:
Bentley Explorer 2004 Edition enables a user to interactively review complex 3D models. The high performance visualization engine of Explorer allows near real-time walkthrough of very large shaded plant models. Explorer supports the review of both DGN and DWG model files as well as other common 3D model formats. Through the use of optional Add-in modules, the functionality of Explorer can be extended to include interference detection, creation of photorealistic images and the publishing of NWD model review files.
Licensed Applications include:
Bentley Explorer - the core module of the design / review solution delivers interactive visualization and real time walkthrough of simple and complex 3D models.
Bentley Explorer Interference Detection Add-in - enables the user to quickly locate, review and manage both hard and clearance clashes in simple and complex geometry.
Bentley Explorer NWD Export Add-in - enables the designer to export large files in compressed and secure .nwd format for full collaborative review of model data independent of the native design software.
Explorer Photorealism Add-in - is a high-end visualization tool for creating both still and animated renderings of complex 3D models. Includes sophisticated texture mapping, materials and lighting for photorealistic output.
Bentley Explorer is the core module and must be licensed and resident on the user system. Each Add-in is licensed independently
GMT+8, 2026-11-4 04:23 , Processed in 0.511563 second(s), 43 queries , Gzip On.
