查看: 1037|回复: 1
[求助]:能否给一个块存储一个数据表的xdata例程
发表于 2002-11-29 19:05:14 | 显示全部楼层 |阅读模式
表的形式如(2 2a)(3 5)(4 7)..... 等
已领礼包: 181个
发表于 2002-11-29 19:08:54 | 显示全部楼层
在所有的实体中都可以存放XDATA数据,看看下面的例子吧,具体怎么存放,那要看你自己怎么控制了。
  1.   [FONT=courier new]
  2. Sub Example_SetXdata()
  3.     ' This example creates a line and attaches extended data to that line.
  4.
  5.     ' Create the line
  6.     Dim lineObj As AcadLine
  7.     Dim startPt(0 To 2) As Double, endPt(0 To 2) As Double
  8.     startPt(0) = 1#: startPt(1) = 1#: startPt(2) = 0#
  9.     endPt(0) = 5#: endPt(1) = 5#: endPt(2) = 0#
  10.     Set lineObj = ThisDrawing.ModelSpace.AddLine(startPt, endPt)
  11.     ZoomAll
  12.     ' Initialize all the xdata values. Note that first data in the list should be
  13.     ' application name and first datatype code should be 1001
  14.     Dim DataType(0 To 9) As Integer
  15.     Dim Data(0 To 9) As Variant
  16.     Dim reals3(0 To 2) As Double
  17.     Dim worldPos(0 To 2) As Double
  18.
  19.     DataType(0) = 1001: Data(0) = "Test_Application"
  20.     DataType(1) = 1000: Data(1) = "This is a test for xdata"
  21.     DataType(2) = 1003: Data(2) = "0"                   ' layer
  22.     DataType(3) = 1040: Data(3) = 1.23479137438413E+40  ' real
  23.     DataType(4) = 1041: Data(4) = 1237324938            ' distance
  24.     DataType(5) = 1070: Data(5) = 32767                 ' 16 bit Integer
  25.     DataType(6) = 1071: Data(6) = 32767                 ' 32 bit Integer
  26.     DataType(7) = 1042: Data(7) = 10                    ' scaleFactor
  27.     reals3(0) = -2.95: reals3(1) = 100: reals3(2) = -20
  28.     DataType(8) = 1010: Data(8) = reals3                ' real
  29.
  30.     worldPos(0) = 4: worldPos(1) = 400.99999999: worldPos(2) = 2.798989
  31.     DataType(9) = 1011: Data(9) = worldPos              ' world space position
  32.
  33.     ' Attach the xdata to the line
  34.     lineObj.SetXData DataType, Data
  35.
  36.     ' Return the xdata for the line
  37.     Dim xdataOut As Variant
  38.     Dim xtypeOut As Variant
  39.     lineObj.GetXData "", xtypeOut, xdataOut
  40.
  41. End Sub
  42.   [/FONT]
GMT+8, 2026-11-2 03:59 , Processed in 0.642628 second(s), 34 queries , Gzip On.
