查看: 1405|回复: 4
[测试]:AutoCAD 2004中的真彩色DXF组码:420
发表于 2002-11-30 08:54:13 | 显示全部楼层 |阅读模式
A 24-bit color value that should be dealt with in terms of bytes with values of 0 to 255. The lowest byte is the blue value, the middle byte is the green value, and the third byte is the red value. The top byte is always 0. The group code cannot be used by custom entities for their own data because the group code is reserved for AcDbEntity, class-level color data and AcDbEntity, class-level transparency data
24位真彩,低8位:蓝色,中8位:绿色,高8位:红色
如下(420 . 7990383):
  1. Command: (entget (car (entsel)))
  2. Select object: ((-1 . <Entity name: 7ef56e88>) (0 . "LINE") (330 . <Entity
  3. name: 7ef56cf8>) (5 . "79") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 .
  4. "0") (62 . 91) (420 . 7990383) (100 . "AcDbLine") (10 296.01 140.244 0.0) (11
  5. 687.142 347.618 0.0) (210 0.0 0.0 1.0))
复制代码
 楼主| 发表于 2002-11-30 09:00:12 | 显示全部楼层
VBA帮助中还没有指出真彩的实现方法
已领礼包: 24个
发表于 2002-12-2 14:33:25 | 显示全部楼层
试一试 : vla-get-TrueColor
发表于 2002-12-14 00:41:06 | 显示全部楼层
啊!2003年还没来,就有CAD2004了。
已领礼包: 943个
发表于 2002-12-14 11:59:12 | 显示全部楼层
CAD奇数版总是有这样那样的问题,现在他们不改起名为奇数的了。
GMT+8, 2026-11-3 10:48 , Processed in 0.618285 second(s), 41 queries , Gzip On.
