查看: 1090|回复: 2
[讨论]:const void * pt1及const 变量,变量 const?
发表于 2004-6-17 10:24:32 | 显示全部楼层 |阅读模式
对于acedSSGet() 中的 const void * pt1还有 const 变量,变量 const的理解?
发表于 2004-6-17 14:34:35 | 显示全部楼层
int
acedSSGet(
const char * str,
const void * pt1,
const void * pt2,
const struct resbuf * filter,
ads_name ss);
str An optional string that specifies the entity selection mode to use
pt1 An optional point relevant to some selection modes; or a result-buffer list that contains multiple points for the polygon or fence selection options; or an array of two strings that are replacement prompts for a :$ mode option
pt2 An optional point relevant to some selection modes
filter An optional result-buffer list that enables acedSSGet() to filter the drawing to select entities of certain types or that have certain properties
ss The name of the selection set
详见arxdoc.chm
发表于 2004-6-18 22:57:37 | 显示全部楼层
int const *,const int *,c++基础讲的很明白的。。。
GMT+8, 2026-11-22 08:43 , Processed in 0.239046 second(s), 14 queries , Gzip On, File On.
