查看: 980|回复: 1
[求助]:大家好,我这儿自编了一个凸轮绘制程序,当然是没有成功,想向各位高手指明我错
发表于 2002-11-30 22:18:02 | 显示全部楼层 |阅读模式
  1.   [FONT=courier new]
  2. Option Explicit
  3. Private Sub CommandButton1_Click()
  4. UserForm1.Hide
  5. Dim s, u, u1, u2, u3, u4, h, e, ro, rt, incrim, s0, beta0, beta, rou, ceta As Double
  6. Dim i As Integer
  7. Dim ptpnts() As Double
  8. Dim pt As Variant
  9. Dim bp As Variant
  10. Dim circleobj As AcadCircle
  11. Dim objpoly As AcadLWPolyline
  12. Dim objline As AcadLine
  13. Dim pt0 As Double
  14. Dim firstpt As Double
  15. Const pi = 3.1415926
  16. u1 = Val(TextBox1.Text)
  17. u2 = Val(TextBox2.Text)
  18. u3 = Val(TextBox3.Text)
  19. u4 = Val(TextBox4.Text)
  20. h = Val(TextBox5.Text)
  21. e = Val(TextBox6.Text)
  22. ro = Val(TextBox7.Text)
  23. rt = Val(TextBox8.Text)
  24. incrim = Val(TextBox9.Text)
  25. i = UserForm1.ComboBox1.ListIndex
  26. bp = ThisDrawing.Utility.GetPoint(, "请输入凸轮基圆中心:")
  27. Set circleobj = ThisDrawing.ModelSpace.AddCircle(bp, ro)
  28. u = 0#
  29. Do Until u <= 360#
  30.    If u <= u1 Then
  31.       Select Case i
  32.          Case 0
  33.            Call isovelocity_up
  34.          Case 1
  35.            Call isoacceleration_up
  36.          Case 2
  37.            Call libration_up
  38.        End Select
  39.       s0 = Sqr((ro ^ 2) - (e ^ 2))
  40.       Print "aaaaa"
  41.       beta0 = Atn(e / s0)
  42.       beta = Atn(e / (s0 + s))
  43.       rou = Sqr((s + s0) ^ 2 + e ^ 2)
  44.       ceta = u * pi / 180# + beta - beta0
  45.       pt = ThisDrawing.Utility.PolarPoint(bp, ceta, rou)
  46.    ElseIf u > u1 And u <= (u1 + u2) Then
  47.       s = h
  48.       s0 = Sqr(ro ^ 2 - e ^ 2)
  49.       beta0 = Atn(e / s0)
  50.       beta = Atn(e / (s0 + s))
  51.       rou = Sqr((s + s0) ^ 2 + e ^ 2)
  52.       ceta = u * pi / 180# + beta - beta0
  53.       pt = ThisDrawing.Utility.PolarPoint(bp, ceta, rou)
  54.    ElseIf u > (u1 + u2) And u <= (u1 + u2 + u3) Then
  55.         Select Case i
  56.           Case 0
  57.             Call isovelocity_down
  58.           Case 1
  59.             Call isoacceleration_down
  60.           Case 2
  61.             Call libration_down
  62.          End Select
  63.        s0 = Sqr(ro ^ 2 - e ^ 2)
  64.        beta0 = Atn(e / s0)
  65.        beta = Atn(e / (s0 + s))
  66.        rou = Sqr((s + s0) ^ 2 + e ^ 2)
  67.        ceta = u * pi / 180# + beta - beta0
  68.        pt = ThisDrawing.Utility.PolarPoint(bp, ceta, rou)
  69.    ElseIf u > (u1 + u2 + u3) Then
  70.        s = 0
  71.        beta0 = Atn(e / s0)
  72.        beta = Atn(e / (s0 + s))
  73.        rou = Sqr((s + s0) ^ 2 + e ^ 2)
  74.        ceta = u * pi / 180# + beta - beta0
  75.        pt = ThisDrawing.Utility.PolarPoint(bp, ceta, rou)
  76.    End If
  77.
  78. If (firstpt <> "") Then
  79.    Set objline = ThisDrawing.ModelSpace.AddLine(pt0, pt)
  80. ElseIf (firstpt = "") Then
  81.    firstpt = pt
  82. End If
  83.
  84.   pt0 = pt
  85.    u = u + incrim
  86.
  87.
  88. Loop
  89. End Sub
  90. Private Sub UserForm_Initialize()
  91. UserForm1.ComboBox1.AddItem "等速运动", 0
  92. UserForm1.ComboBox1.AddItem "等加速和等减速运动", 1
  93. UserForm1.ComboBox1.AddItem "简谐运动", 2
  94. UserForm1.ComboBox1.AddItem "摆线运动", 3
  95. UserForm1.ComboBox1.ListIndex = 0
  96. UserForm1.TextBox1.SetFocus
  97. End Sub
  98. Public Sub isovelocity_up()
  99. s = h * u / u1
  100. End Sub
  101. Public Sub isoacceleration_up()
  102.   If u < ui / 2 Then
  103.      s = 2 * h * u ^ 2 / u1 ^ 2
  104.   Else
  105.      s = h - 2 * h * ((u - u1) ^ 2) / (u1 ^ 2)
  106.   End If
  107. End Sub
  108. Public Sub isovelocity_down()
  109. s = h * (1 - u / u3)
  110. End Sub
  111. Public Sub isoacceleration_down()
  112.   If u < u3 / 2 Then
  113.      s = h - 2 * h * u62 / u3 ^ 2
  114.   Else
  115.      s = 2 * h * ((u - u3) ^ 2) / (u3 ^ 2)
  116.   End If
  117. End Sub
  118. Public Sub libration_up()
  119. s = h * (1 - Cos(pi * u / u1))
  120. End Sub
  121. Public Sub libration_down()
  122. s = h * (1 + Cos(pi * u / u3)) / 2
  123. End Sub
  124.   [/FONT]
发表于 2002-11-30 22:27:04 | 显示全部楼层
最好说明一下设计原理,用到的方法,这样子别人才能明白你是怎么设计的。
GMT+8, 2026-11-22 10:38 , Processed in 0.244057 second(s), 13 queries , Gzip On, File On.
