查看: 1107|回复: 5
[ARX函数]:BOOL filterMouse(MSG *pMsg) 取坐标为何与状态栏的现实有一定的误差?
发表于 2004-6-20 23:40:46 | 显示全部楼层 |阅读模式
if( pMsg->message == WM_MOUSEMOVE )
  acedDwgPoint cpt;
  ads_point ptDCS, ptWCS, norm;
  AcGePoint3d  origin;
  AcGeVector3d e0, e1, e2;
  AcGeMatrix3d  matUcs2Wcs, matWcs2Ucs;
  // 1: Get the Mouse coords in DCS
  CPoint cPnt (pMsg->lParam) ;
  acedCoordFromPixelToWorld (cPnt, cpt) ;
  acdbPointSet ( cpt, ptDCS );
  //acutPrintf ( "\nMouse in Ucs %f, %f, %f",  ptDCS[X], ptDCS[Y],ptDCS[Z] );
   //return FALSE;
  // 2: Transform the Mouse coords from DCS to WCS
  // For this we use the    acdbEcs2Ucs  function with the
  // value of the VIEWDIR system variable as the input normalvector of ECS
  // (Sure we have to transform the VIEWDIR value from UCS to WCS
  struct resbuf rbview;
  acedGetVar( "viewdir", &rbview );
  ads_point_set( rbview.resval.rpoint, norm );
  // If the view direction is 0, 0, 1, then acedCoordFromPixelToWorld()
  // needs special handling -> we only have to translate the thepoint
   // by the distance the origin of the current UCS was moved
  double tol = 1e-10;
  if ((fabs(norm[X]) < tol) && (fabs(norm[Y]) < tol) &&((fabs(norm[Z]) - 1.0) < tol))
   AcGePoint3d acadPt;
   acadPt.x = cpt[0];
   acadPt.y = cpt[1];
   acadPt.z = cpt[2];
   acdbUcsMatrix ( matUcs2Wcs );
   matUcs2Wcs.invert();
   matUcs2Wcs.getCoordSystem( origin, e0, e1, e2);
   acadPt += origin.asVector();
   acutPrintf ( "\nMouse in Ucs %f, %f, %f",  acadPt[X],acadPt[Y], acadPt[Z] );
   return FALSE;
  //transfoming VIEWDIR  to WCS
  acdbUcs2Wcs ( norm, norm, Adesk::kTrue );
  // Transforming the mouse coords from DCS to WCS
  acdbEcs2Wcs( ptDCS, ptWCS, norm, Adesk::kTrue );
  // 3: Get the Mouse coordinates in UCS        //
  // For this we have to project the WCS coordinates to the UCSplane using
  // the VIEWDIR vector as projection direction.        //
  // Getting the UCS->WCS transformation matrix
  // Creating a plane which lies on the current UCS
  AcGePlane thePlane ( origin, e0, e1);
  AcGePoint3d  pntMouseInWCS( ptWCS[X], ptWCS[Y], ptWCS[Z] );
  AcGeVector3d vecViewdir( norm [X], norm [Y], norm [Z] );
  // Making the projection
  AcGePoint3d resPnt = pntMouseInWCS.project (thePlane, vecViewdir);
  // Transforming the point coordinates to UCS.
  matWcs2Ucs = matUcs2Wcs.inverse();
  resPnt.transformBy ( matWcs2Ucs );
  //this line prints the same coordinates as the coordinates
  //shown in  AutoCAD's status bar
  acutPrintf ( "\nMouse in Ucs %f, %f, %f",  resPnt[X], resPnt[Y],resPnt[Z] );    }
  return FALSE; // continue
发表于 2004-6-22 09:40:22 | 显示全部楼层 |阅读模式
你将视区放大,会发现差值越来越小
 楼主| 发表于 2004-6-22 11:05:58 | 显示全部楼层
非常感谢,可有什么办法解决吗?
发表于 2004-6-23 08:50:07 | 显示全部楼层
没有办法,提供的只是大约的数字。
要准确的话就提供捕捉或直接输入坐标
 楼主| 发表于 2004-6-23 09:11:24 | 显示全部楼层
谢谢~~~
发表于 2004-6-23 12:01:05 | 显示全部楼层
AcEdInputPointMonitor
GMT+8, 2026-11-2 23:27 , Processed in 0.459187 second(s), 44 queries , Gzip On.
