查看: 1631|回复: 1
[求助]:请教xd:见内!谢谢!
发表于 2002-3-7 23:50:37 | 显示全部楼层 |阅读模式
一:获得块的相关坐标。见附件
    因为我要对块进行管理,如相关块统计、各个块端点的属性等
二:关于钩子问题。
  昨天从您处获得的代码加入钩子后所获得的坐标不对,麻烦帮我看看,谢谢!
  生成钩子:
  m_hHook=::SetWindowsHookEx(WH_MOUSE,MouseHookProc,(HINSTANCE)NULL,GetCurrentThreadId());
  钩子函数:
LRESULT CALLBACK MouseHookProc(int nCode,WPARAM wParam,LPARAM lParam)
acedDwgPoint cpt;
ads_point ptDCS, ptWCS, norm;
AcGePoint3d  origin;
AcGeVector3d e0, e1, e2;
AcGeMatrix3d  matUcs2Wcs, matWcs2Ucs;
// 1: Get the Mouse coords in DCS
CPoint cPnt (lParam) ;
acedCoordFromPixelToWorld (cPnt, cpt) ;
acdbPointSet ( cpt, ptDCS );
//acutPrintf ( "\nMouse in Ucs %f, %f, %f",  ptDCS[X], ptDCS[Y],ptDCS[Z] );
//return FALSE;
// 2: Transform the Mouse coords from DCS to WCS
// For this we use the    acdbEcs2Ucs  function with the
// value of the VIEWDIR system variable as the input normalvector of ECS
// (Sure we have to transform the VIEWDIR value from UCS to WCS
struct resbuf rbview;
acedGetVar( "viewdir", &rbview );
ads_point_set( rbview.resval.rpoint, norm );
// If the view direction is 0, 0, 1, then acedCoordFromPixelToWorld()
// needs special handling -> we only have to translate the thepoint
// by the distance the origin of the current UCS was moved
double tol = 1e-10;
if ((fabs(norm[X]) < tol) && (fabs(norm[Y]) < tol) &&((fabs(norm[Z]) - 1.0) < tol))
AcGePoint3d acadPt;
acadPt.x = cpt[0];
acadPt.y = cpt[1];
acadPt.z = cpt[2];
acdbUcsMatrix ( matUcs2Wcs );
matUcs2Wcs.invert();
matUcs2Wcs.getCoordSystem( origin, e0, e1, e2);
acadPt += origin.asVector();
acutPrintf ( "\nMouse in Ucs %f, %f, %f",  acadPt[X],acadPt[Y], acadPt[Z] );
  //transfoming VIEWDIR  to WCS
acdbUcs2Wcs ( norm, norm, Adesk::kTrue );
// Transforming the mouse coords from DCS to WCS
acdbEcs2Wcs( ptDCS, ptWCS, norm, Adesk::kTrue );
// 3: Get the Mouse coordinates in UCS        //
// For this we have to project the WCS coordinates to the UCSplane using
// the VIEWDIR vector as projection direction.        //
// Getting the UCS->WCS transformation matrix
// Creating a plane which lies on the current UCS
AcGePlane thePlane ( origin, e0, e1);
AcGePoint3d  pntMouseInWCS( ptWCS[X], ptWCS[Y], ptWCS[Z] );
AcGeVector3d vecViewdir( norm [X], norm [Y], norm [Z] );
// Making the projection
AcGePoint3d resPnt = pntMouseInWCS.project (thePlane, vecViewdir);
// Transforming the point coordinates to UCS.
matWcs2Ucs = matUcs2Wcs.inverse();
resPnt.transformBy ( matWcs2Ucs );
//this line prints the same coordinates as the coordinates
//shown in  AutoCAD's status bar
acutPrintf ( "\nMouse in Ucs %f, %f, %f",  resPnt[X], resPnt[Y],resPnt[Z] );
return CallNextHookEx(m_hHook,nCode,wParam,lParam);
已领礼包: 145个
发表于 2002-3-8 02:54:12 | 显示全部楼层
Re: [求助]:请教xd:见内!谢谢!
最初由 梦宁 发布
[B]一:获得块的相关坐标。见附件
二:关于钩子问题。
  生成钩子:
  m_... [/B]
1.座标怎么不对,昨天的代码是获得UCS下的座标,如要WCS下的,用转换矩阵转换下就可以,另外,ARX有自己的定义钩子的函数。acedRegisterFilterWinMsg等。
2. 你可以遍历AcDbBlockTableRecord,获得块内的每个实体的终点,起点座标,然后根据AcDbBlockRefence的插入的转换矩阵换算到INSERT示例上的点。
GMT+8, 2026-11-2 21:45 , Processed in 0.446921 second(s), 35 queries , Gzip On.
