查看: 924|回复: 1
[求助]:启动显示有error
发表于 2004-6-28 15:49:38 | 显示全部楼层 |阅读模式
Regenerating model.
错误: LOAD failed: "test_w.lsp"
AutoCAD menu utilities loaded._menu Enter menu file name or [. (for none)]
<C:\Program Files\AutoCAD 2002\support\acad>: C:\Program Files\AutoCAD
2002\support\acad.mnu
ERROR ->  Menu Syntax Error Line: 902.
ERROR ->  Menu Syntax Error Line: 1210.
ERROR ->  Menu Syntax Error Line: 1213.
ERROR ->  Menu Syntax Error Line: 1214.
ERROR ->  Menu Syntax Error Line: 1215.
ERROR ->  Menu Syntax Error Line: 1216.
Menu loaded successfully. MENUGROUP: ACAD
How can I solve this problem?  Thank you!
发表于 2004-6-28 15:53:11 | 显示全部楼层
从别的机器拷各acad.mnu过来 放到C:\Program Files\AutoCAD
2002\support\acad.mnu,最好重置一下cad设置
GMT+8, 2026-11-23 18:09 , Processed in 0.597083 second(s), 12 queries , Gzip On, File On.
