查看: 1297|回复: 2
[求助]:ThisDrawing.ModelSpace
发表于 2004-7-2 10:18:04 | 显示全部楼层 |阅读模式
Dim a As AcadExternalReference
Set a = ThisDrawing.ModelSpace.AttachExternalReference("D:\ht\w.dwg", "abc", pnt, 1, 1, 1, 0, False)
MsgBox "Click me to ReLoad"
ThisDrawing.Blocks("abc").Path = "d:\sgt\2w.dwg"
ThisDrawing.Blocks("abc").Reload
这段语句运行到Set a = ThisDrawing.ModelSpace.AttachExternalReference("D:\ht\w.dwg", "abc", pnt, 1, 1, 1, 0, False),老是提示说要求对象,不知怎么回事!请各位大哥指点一下*-*4
发表于 2004-7-2 11:11:48 | 显示全部楼层
你是在VB还是VBA里编写的?
已领礼包: 181个
发表于 2004-7-2 13:56:17 | 显示全部楼层
那句是没有错的,但ThisDrawing.Blocks("abc").Path = "d:\sgt\2w.dwg"却错了,Path只能对外部引用,而不能对块。
GMT+8, 2026-11-3 15:19 , Processed in 0.425051 second(s), 36 queries , Gzip On.
