查看: 1666|回复: 2
[求助] [求助]:谁帮我看看这个程序有什么问题?
发表于 2008-4-28 16:30:25 | 显示全部楼层 |阅读模式
;;;功能:输出矩形长宽
(defun c:CS ()
  (vl-load-com)
  (setq modelspace (vla-get-Modelspace (vla-get-activeDocument(vlax-get-acad-object))))
;;;计算长和宽
  (setq ss (ssget))
  (setq ent (ssname ss 0))
  (setq di (vlax-curve-getDistAtParam ent 1))
  (setq dj (- (vlax-curve-getDistAtParam ent 2) di))
  (setq text1(strcat "L= "(rtos di 2 0) "  B= "(rtos dj 2 0)))
;;;计算插入点
  (setq p1 (vlax-curve-getstartpoint ent))
  (setq p3 (vlax-curve-getPointAtParam endObj (+ di dj))
  (setq x1 (car p1))
  (setq y1 (cadr p1))
  (setq x3 (car p3))
  (setq y3 (cadr p3))
  (setq x0 (/ (+ x1 x3) 2))
  (setq y0 (/ (+ y1 y3) 2))
;;;插入文字
  (if(setq insertpt (cons x0 y0))
    (if(setq height (/ di 20))
       textobj1 (vla-addtext modelspace text1 insertp height)
发表于 2008-4-28 22:00:47 | 显示全部楼层
;;;功能:输出矩形长宽
(defun c:test ()
  (vl-load-com)
                     (vla-get-activeDocument (vlax-get-acad-object))
        ;; 计算长和宽
        ent           (ssname (ssget) 0)
        text           (strcat "L= " (rtos di 2 0) " B= " (rtos dj 2 0))
        ;; 计算插入点
        p3           (vlax-curve-getPointAtParam ent 2)
        x1           (car p1)
        y1           (cadr p1)
        x3           (car p3)
        y3           (cadr p3)
        x0           (/ (+ x1 x3) 2)
        y0           (/ (+ y1 y3) 2)
  ;; 插入文字
  (if (setq insertpt (list x0 y0 0))
    (if        (setq height (/ di 20))
                   text
                   (vlax-3D-point insertpt)
                   height
 楼主| 发表于 2008-4-29 09:47:17 | 显示全部楼层
非常漂亮,谢谢!
GMT+8, 2026-11-22 08:07 , Processed in 0.428023 second(s), 14 queries , Gzip On, File On.
