查看: 1162|回复: 1
[日积月累]:利用ObjectDbx预览块图像
发表于 2004-7-2 12:01:35 | 显示全部楼层 |阅读模式
Private pFileName As String
Private objDbx As AxDbDocument
Public Names As New Collection
Private Sub Class_Initialize()
    Set objDbx = GetInterfaceObject("ObjectDBX.AxDbDocument.16")
End Sub
Public Function GetBlock(ByVal BlockName As String) As AcadBlock
'将文件中的块读入当前图形
    Dim pBlock As AcadBlock
    Dim pnt(2) As Double
    Dim pObjs() As AcadEntity
    Set pBlock = objDbx.Blocks(BlockName)
    ReDim pObjs(pBlock.Count - 1) As AcadEntity
    For i = 0 To pBlock.Count - 1
        Set pObjs(i) = pBlock(i)
    Next i
    Set GetDbxBlock = ThisDrawing.Blocks.Add(pnt, "*U")
    objDbx.CopyObjects pObjs, GetDbxBlock
End Function
Public Function GetBlockImage(ByVal BlockName As String) As IPictureDisp
'获取块的预览图像
    Dim pObj(0) As AcadEntity
    Dim ss As AcadSelectionSet
    Set pObj(0) = objDbx.ModelSpace.InsertBlock(pnt, BlockName, 1, 1, 1, 0)
    objDbx.CopyObjects pObj, ThisDrawing.ModelSpace
    Set pObj(0) = ThisDrawing.ModelSpace(ThisDrawing.ModelSpace.Count - 1)
    pObj(0).GetBoundingBox d1, d2
    ThisDrawing.Application.ZoomWindow d1, d2
    On Error Resume Next
    ThisDrawing.SelectionSets("*TlsDbx*").Delete
    Set ss = ThisDrawing.SelectionSets.Add("*TlsDbx*")
    ss.AddItems pObj
    ThisDrawing.Export "c:\Temp", "wmf", ss
    ss.Delete
    pObj(0).Delete
    ThisDrawing.Blocks(BlockName).Delete
    ThisDrawing.Application.ZoomPrevious
    Set GetBlockImage = LoadPicture("c:\temp.wmf")
    Kill "c:\temp.wmf"
End Function
Public Property Let FileName(ByVal str As String)
'打开文件
    Dim i As AcadBlock
    pFileName = str
    objDbx.Open str
    Set Names = New Collection
    For Each i In objDbx.Blocks
        If Not (i.IsLayout Or i.IsXRef) Then
            Names.Add i.Name
        End If
    Next i
End Property
上述代码存为TlsDbx类
插入一个窗体
加入ListBox控件和Image控件
在窗体加入下列代码
Dim a As New TlsDbx
Private Sub ListBox1_Click()
Set Me.Image1.Picture = a.GetBlockImage(ListBox1.Text)
End Sub
Private Sub UserForm_Activate()
a.FileName = "d:\ccd.dwg"
For Each i In a.Names
Me.ListBox1.AddItem i
Debug.Print i
Next i
End Sub
谢谢efan斑竹的提议,已修正过
已领礼包: 181个
发表于 2004-7-2 14:00:24 | 显示全部楼层
块有三种对象,一是布局,像模型空间,图纸空间,可以使用IsLayout来判断,二是外部引用,即将另一图纸插入到当前图纸中,可以使用IsXRef来判断,剩下的就是普通意义上的块了。
GMT+8, 2026-11-3 00:42 , Processed in 0.429575 second(s), 33 queries , Gzip On.
