查看: 928|回复: 5
[求助] [求助]:如何取与某多义线有交点的线
发表于 2004-7-17 13:35:06 | 显示全部楼层 |阅读模式
请教一个问题, 我想取与某方形多义线有交点的线, 取出线点表plst 用 (setq ss2 (ssget "cp" plst )),发现取到的线和它没有交点,请问原因?
或有其它办法取与某多义线有交点的线吗
发表于 2004-7-17 14:03:42 | 显示全部楼层
是虚线?
 楼主| 发表于 2004-7-17 14:26:25 | 显示全部楼层
lwpolyline 并非虚线
发表于 2004-7-17 14:51:40 | 显示全部楼层
;;此程序适用于不同形状的边界,还可得到交点值。
;;仅作参考,实际上按你的要求可能不用这么复杂。
(defun C:TT  (/ plineobj ss ss_found idx en en1)
  (vl-load-com)
  (setq        plineObj (vlax-ename->vla-object
                   (setq en (car (entsel "\n选择多义线: ")))))
  ;;可以选择任何图元(除Pviewport和PolygonMesh外)
  (setq ss (ssget "x" '((0 . "*LINE"))))
  ;;实际上可以任何图元
  (setq        ss_found (ssadd)
        idx         -1)
  (if ss
    (progn
      (repeat (sslength ss)
        (setq en1 (ssname ss (setq idx (1+ idx))))
        (if (and (VxGetInters
                   plineObj
                   (vlax-ename->vla-object en1)
                   acExtendNone)
                 (not (eq en en1)))
          (setq ss_found (ssadd en1 ss_found)))
      (princ (strcat "\n找到 "
                     (itoa (sslength ss_found))
                     " 个相交图元。"))
      (SS_hilite ss_found 3)
    (princ "\n没有找到相交图元.")
  (princ)
; From MENZI ENGINEERING GmbH, Switzerland
(defun VxGetInters  (Fst Nxt Mde / IntLst PntLst)
  (setq IntLst (vlax-invoke Fst "IntersectWith" Nxt Mde))
  (cond
    (IntLst
     (repeat (/ (length IntLst) 3)
       (setq PntLst (cons
                      (list
                        (car IntLst)
                        (cadr IntLst)
                        (caddr IntLst)
                      PntLst
             IntLst (cdddr IntLst)
     (reverse PntLst)
    (T nil)
;; From GeoTool
(defun SS_hilite  (ss mode / ssl cnt)
  (if ss
    (progn
      (setq
        ssl (sslength ss)
        cnt 0
      (repeat ssl
        (redraw (ssname ss cnt) mode)
        (setq cnt (1+ cnt))
发表于 2004-7-17 14:57:17 | 显示全部楼层
(SSGET "F" PLST)
发表于 2004-7-17 19:29:32 | 显示全部楼层
谢谢aidraft ,我从你这里学到了知识
GMT+8, 2026-11-4 23:01 , Processed in 0.484376 second(s), 42 queries , Gzip On.
