查看: 894|回复: 5
[求助] [求助]:vla函数如何用法???
发表于 2004-7-20 13:14:05 | 显示全部楼层 |阅读模式
请教众为高手
VLA-GETOBJECTatPOINT 的表达式如何写
(setq ss(VLA-GETOBJECTatPOINT  POINT));;其中POINT为VLAX-DOUBLE 类型坐标点VARINT.
错在哪里?
发表于 2004-7-20 14:14:50 | 显示全部楼层
Where did get this method?
 楼主| 发表于 2004-7-20 23:39:07 | 显示全部楼层
由VBA表达式转化过来
发表于 2004-7-21 09:25:47 | 显示全部楼层
I can't find this method in 2004
发表于 2004-7-21 15:04:52 | 显示全部楼层
是要这个么?
[php]
SelectAtPoint Method
Selects an object passing through a given point and places it into a selection set.
See Also | Example
Signature
object.SelectAtPoint Point, FilterType, FilterData
Object
SelectionSet
The object or objects this method applies to.
Point
Variant (three-element array of doubles); input-only
The 3D WCS coordinates specifying the point to use for the selection.
FilterType
Integer; input-only; optional
A DXF group code specifying the type of filter to use.
FilterData
Variant; input-only; optional
The value to filter on.
Remarks
This method supports the filtering mechanism.
For more selection mode options, see the Select, SelectByPolygon, and SelectOnScreen methods.
[/php]
 楼主| 发表于 2004-7-22 12:47:56 | 显示全部楼层
我是按照这个说明写的,可是我实现不了啊,可否来一段可以实现的代码?
谢谢!
GMT+8, 2026-11-4 21:04 , Processed in 0.879824 second(s), 42 queries , Gzip On.
