查看: 994|回复: 4
[LISP程序]:改进的鼠标拖动序号球程序-引线可是LEADER/LINE
发表于 2004-7-20 17:10:14 | 显示全部楼层 |阅读模式
[php]
(defun c:test (/ leobj liobj)
  (vl-load-com)
  (setq loop t)
  (setq ss (ssget))
  (setq n 0)
  (while (< n (sslength ss))
    (setq obj (vlax-ename->vla-object (ssname ss n)))
    (setq oname (vla-get-ObjectName obj))
    (cond
      ((= oname "AcDbLeader")
        (setq leobj obj p1 (vlax-curve-getstartpoint (ssname ss n))))
      ((= oname "AcDbLine")
        (setq liobj obj p1 (vlax-curve-getstartpoint (ssname ss n))
                        p2 (vlax-curve-getendpoint (ssname ss n))))
      ((= oname "AcDbCircle")(setq ccobj obj pc (cdr (assoc 10 (entget (ssname ss n))))))
      ((= oname "AcDbText")(setq ttobj obj))
    (setq n (1+ n))
  (if liobj (if (< (distance p1 pc)(distance p2 pc))(setq p0 p1 p1 p2 p2 p0)))
  (while loop
    (setq p (grread T))
    (if (= (car p) 3)(setq loop nil))
    (vla-put-center ccobj (vlax-3d-point (cadr p)))
    (vla-put-textalignmentpoint ttobj (vlax-3d-point (cadr p)))
    (setq pc (vlax-safearray->list (vlax-variant-value (vla-get-center ccobj))))
    (setq p2 (polar pc (angle pc p1)(vla-get-radius ccobj)))
    (cond
      (leobj
              (setq sl (vlax-make-safearray vlax-vbdouble '(0 . 5)))
        (setq sa (vlax-safearray-fill sl (append p1 p2)))
        (vla-put-coordinates leobj sa)
        (vla-update leobj))
      (liobj
        (vla-put-startpoint liobj (vlax-3d-point p1))
        (vla-put-endpoint liobj (vlax-3d-point p2))
        (vla-update liobj))
[/php]
已领礼包: 488个
发表于 2004-7-21 20:52:38 | 显示全部楼层
不就是move命令吗!?
(ssget)选的东西,不能多也不能少,应该先判断.
如果加点其他功能,比如按一键,左右镜像..等等,那你写它才有意义,不然还不如用move.
 楼主| 发表于 2004-7-22 04:43:52 | 显示全部楼层
最初由 aeo 发布
[B]不就是move命令吗!?... [/B]
斑竹说的轻巧!? 你给MOVE个看看?!
发表于 2004-11-6 06:59:52 | 显示全部楼层
最好传一个测试图上来
发表于 2004-11-6 09:09:13 | 显示全部楼层
没有具体明白是什么意思?可否传张图上来看看?
GMT+8, 2026-11-5 10:55 , Processed in 0.405280 second(s), 40 queries , Gzip On.
