查看: 1114|回复: 1
[求助]:怎样调用一个外部的.txt文件
发表于 2002-12-20 22:00:41 | 显示全部楼层 |阅读模式
谢谢!十万火急!请各位多多帮忙!
怎样调用一个外部的.txt或.dat文件中的数据为lisp的程序的计算所用
发表于 2002-12-20 22:44:35 | 显示全部楼层
这是郑立楷先生的一个范例程序:
  1. (defun c:pltxt (/ oldcmd oldblip oldsnap fle fn pt)
  2.   (setq oldcmd (getvar "cmdecho"))
  3.   (setvar "cmdecho" 0)
  4.   (setq oldblip (getvar "blipmode"))
  5.   (setvar "blipmode" 0)
  6.   (setq oldsnap (getvar "osmode"))
  7.   (setvar "osmode" 0)
  8.   (setq fle (findfile "txt1.txt"))
  9.   (if (not fle)
  10.     (setq fle (getfiled "请选择数据文件" "txt1" "txt;dat;*" 8))
  11.   )
  12.   (if fle
  13.     (progn
  14.       (setq fn (open fle "r"))
  15.       (read-line fn)
  16.       (read-line fn)
  17.       (command "pline")
  18.       (while (setq pt (read-line fn))
  19. (command (read (strcat "(" pt ")")))
  20.       )
  21.       (command "")
  22.       (close fn)
  23.     )
  24.     (princ "\n未选择数据文件,退出")
  25.   )
  26.   (setvar "cmdecho" oldcmd)
  27.   (setvar "blipmode" oldblip)
  28.   (setvar "osmode" oldsnap)
  29.   (princ)
  30. )
GMT+8, 2026-11-3 00:31 , Processed in 0.433600 second(s), 34 queries , Gzip On.
