查看: 2289|回复: 16
[编程申请]:椭圆和样条曲线怎么加粗?
发表于 2004-8-19 09:01:15 | 显示全部楼层 |阅读模式
椭圆和样条曲线都不能加粗,而且勾轮廓线的时候不能和多线段(pline)连接.
有什么方法吗? *-*2
已领礼包: 12493个
发表于 2004-8-19 09:24:37 | 显示全部楼层
将PELLIPSE设为1后再画椭圆可以得到用16段PLINE弧组成的椭圆,但设定PELLIPSE参数后不能画椭圆弧。
样条曲线必须转成PLINE线才能加粗。好象论坛上有专门的程序。
 楼主| 发表于 2004-8-20 08:38:54 | 显示全部楼层
是什么程序?名称是什么?我搜索没找到
已领礼包: 12493个
发表于 2004-8-20 10:40:58 | 显示全部楼层
我从明经通道找了一个程序:
 楼主| 发表于 2004-8-21 09:52:22 | 显示全部楼层
最初由 zxq0220 发布
[B]我从明经通道找了一个程序: [/B]
我现在爱心币不够,不能下载.呢给个地址吗?我直接下载.
发表于 2004-8-21 17:36:02 | 显示全部楼层
;;思路:判断ptlist(spline的各个节点的表)中前后两点的斜率是否一样。
;;BY LUCAS(龙龙仔)
;;将spline等分为n个弧,再转为pline
;;只对2D spline有效, 3D spline要改用3dpoly
;;程序其实有个bug,对直线的spline会出错,用一个偷懒的办法解决了.
(defun C:SPLINE_TO_PLINE (/ HOLDECHO    OS   SSS NUMPT N
     ED ED1   PTST  PTEND SS2 PT1   PT2
     PT3 J     ENT   NNO   SS SSL
   ptlist b )
  (defun VAL1 (N SS INDEX)
    (cdr (assoc N (entget (ssname SS INDEX))))
  (defun CH_IT (NOS)
    (if (assoc NOS ED)
      (progn
(if (assoc NOS ENT)
   (setq ENT (subst (assoc NOS ED) (assoc NOS ENT) ENT))
   (setq ENT (append ENT (list (assoc NOS ED))))
(entmod ENT)
  (setq HOLDECHO (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (command "_.undo" "group")
  (setq OS (getvar "osmode"))
  (setvar "osmode" 0)
  (prompt "\nPlease pick the spline: ")
  (setq SSS (ssget '((0 . "spline"))))
  (if SSS ;if1
    (progn;progn1
      (initget (+ 1 2 4))
      (setq NUMPT
      (getint
        "\nPlease specify the accuracy of conversion: "
      (setq N 0)
      (setq SSL (sslength SSS))
      (repeat SSL ;repeat1
(prompt (strcat "\r余 " (itoa (- SSL N)) " 个物件     "));相当于进度条
(setq ED1 (ssname SSS N))
(setq ED (entget ED1))
(setq ptlist (pp ed))
(leo ptlist)
(setq PTST  (cdr (assoc 10 ED)) ;取得起点坐标
       PTEND (cdr (assoc 10 (reverse ED)));取得终点坐标
           (if  (= b 123)
             (progn ;progn3
              (command "erase" ed1 "")
              (command "pline" ptst ptend "")
              (setq N (1+ N))
             );end progn3
             (progn ;progn2
(command "_.divide" ED1 (* 2 NUMPT))
(setq SS2 (ssget "p"))
  (if (= (logand (cdr (assoc 70 ED)) 1) 1)
   (setq J 1)
   (setq J 0)
(setq PT3 PTST)
(setq SS (ssadd))
(repeat NUMPT;repeat2
   (setq PT2 (VAL1 10 SS2 J))
   (if (/= NUMPT (/ (+ J 2) 2))
     (setq PT1 (VAL1 10 SS2 (+ 1 J)))
     (setq PT1 PTEND)
   (command "_.arc" PT3 PT2 PT1)
   (ssadd (entlast) SS)
   (setq PT3 PT1)
   (setq J (+ 2 J))
);end repeat2
(command "_.pedit" (ssname SS 1) "" "j" SS "" "")
(setq ENT (entget (entlast)))
(foreach NNO '(6 8 62 48)
   (CH_IT NNO)
(command "_.erase" SS2 ED1 "")
(setq N (1+ N))
            );end progn2
          );end if2
      );end repeat1
      (prompt (strcat "\r完成转换                               ")
    );end progn1
    (alert "Nothing selected!!")
  );end if1
  (setvar "osmode" OS)
  (command "_.undo" "end")
  (setvar "cmdecho" HOLDECHO)
  (princ)
(defun pp (obj /)
(vl-load-com)
(MASSOC 10  obj)
(defun massoc (key alist / x nlist)
(foreach x alist
(if (eq key (car x))
(setq nlist (cons (cdr x) nlist))
(reverse nlist)
;判断一个表中的各点的是不是在一直线上
(defun leo (listpoint / listnumber listpoint ang1 ang a list_pt)
  (setq list_pt listpoint)
  (setq listnumber (length list_pt))
  (if (>= listnumber 2)
     (setq ang1 (angle (car list_pt) (cadr list_pt)))
  (setq a 1)
  (while (and (>= listnumber 2) (= a 1))
    (setq ang (angle (car list_pt) (cadr list_pt)))
    (if (equal ang1 ang 0.000001)
       (setq a 1)
       (setq a 2)
    (setq ang1 ang)
    (setq list_pt (cdr list_pt))
  (if (= listnumber 1)
    (setq b 123)
    (setq b 456)  ;b在主程序中设成变量
(print)
(prompt "\nType SPLINE_TO_PLINE to run")
(print)
 楼主| 发表于 2004-8-23 10:47:06 | 显示全部楼层
不明白
发表于 2004-8-27 14:57:55 | 显示全部楼层
怎么用啊
已领礼包: 12493个
发表于 2004-8-27 15:26:01 | 显示全部楼层
1、将程序拷贝到ACAD的支持目录SUPPORT中;
2、在命令行键入(load"spline-pline"),或用工具(T)-APPLOAD加载应用程序进行加载;
3、在命令行键入SPLINE_TO_PLINE执行,并根据提示选择SPLINE。
发表于 2004-9-11 10:19:40 | 显示全部楼层
谢谢你的程序!
有个问题请教一下:
这一行要指定精度,其实是圆弧段数,能否输入真正的精度,如:0.005呢?
已领礼包: 12493个
发表于 2004-9-11 19:59:02 | 显示全部楼层
程序不是我写的。如果您能看懂程序,可以自己改改看。我的思路是这样的:先用将曲线分为4段,用求得的曲线长度(或面积)与原曲线长度(或面积)进行比较,如果误差大于给定值,则删去新曲线,段数加倍再画,直致满足要求。
另外贴一个椭圆(弧)转换程序,让大家试用。
发表于 2004-9-13 13:42:30 | 显示全部楼层
谢谢了!刚刚好解决了我现存的问题!
发表于 2004-9-14 23:13:43 | 显示全部楼层
将圆切个小口,在试试编辑。好象可以变粗,但只限与圆
发表于 2004-9-15 22:47:10 | 显示全部楼层
切个小口可以改
发表于 2004-9-17 13:33:59 | 显示全部楼层
这样试试
GMT+8, 2026-11-6 15:07 , Processed in 0.577983 second(s), 58 queries , Gzip On.
