查看: 5109|回复: 4
返回曲线长度
发表于 2013-4-28 13:53:21 | 显示全部楼层 |阅读模式
函数功能:返回曲线长度
[pcode=lisp,true](defun GetCurveLength (curve / )
(setq curve (vlax-ename->vla-object curve))
(vlax-curve-getDistAtParam curve
(vlax-curve-getEndParam curve)
示例: (GetCurveLength(car (entsel)))
[/pcode]
本帖被以下淘专辑推荐:
发表于 2013-6-16 10:42:29 | 显示全部楼层
  1. ;;; ==================================================================
  2. ;;;抄来的
  3. ;;; circle,polyline,lwpolyline,arc,spline,ellipse,line
  4. (defun t2-get-curve-length (e)
  5.   (if (vlax-property-available-p
  6.         (vlax-ename->vla-object e)
  7.         "length"
  8.       )
  9.     (vla-get-length (vlax-ename->vla-object e))
  10.     0
  11.   )
  12. )
  13. ;;; ==================================================================
  14. (defun th-get-curve-length (obj / len)
  15.   (if (vl-catch-all-error-p
  16.         (setq len (vl-catch-all-apply
  17.                     '(lambda
  18.                        ()
  19.                         (vlax-curve-getdistatparam
  20.                           obj
  21.                           (vlax-curve-getendparam obj)
  22.                         )
  23.                      )
  24.                   )
  25.         )
  26.       )
  27.     0
  28.     len
  29.   )
  30. )
  31. ;;; ==================================================================
  32. (defun th-get-curve-length-ss (ss / i l s1 sum)
  33.   (or
  34.     ss
  35.     (setq ss (ssget '((0 . "CIRCLE,ELLIPSE,*LINE,ARC"))))
  36.   )
  37.   (setq        sum 0
  38.         i -1
  39.   )
  40.   (if ss
  41.     (while (setq s1 (ssname ss (setq i (1+ i))))
  42.       (setq l        (th-get-curve-length s1)
  43.             sum        (+ sum l)
  44.       )
  45.     )
  46.   )
  47.   sum
  48. )
  49. ;;; ==================================================================
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 资料分享奖!
查看全部评分
发表于 2013-6-16 20:54:23 | 显示全部楼层
感谢ScmTools 版主及taner 分享函数
向两位学习了!
{:soso_e100:}
发表于 2013-6-17 07:23:10 | 显示全部楼层
已经用上了,好东西!
发表于 2015-2-16 09:50:57 | 显示全部楼层
怎么用a !!!!1111111
GMT+8, 2026-11-22 07:58 , Processed in 0.296119 second(s), 20 queries , Gzip On, File On.
