查看: 1099|回复: 2
[讨论]:關於chenronglin 和aidraft 所發的一個局部放大程序
发表于 2004-8-20 15:22:38 | 显示全部楼层 |阅读模式
請問大大,你的程序,放大出來後,放大圓底下的Enlarged 2x 註解文字怎不會跟著圖紙比例變另?文字好小哦,請教教小弟如何更改,另外可以拿掉Changed 2 objects, Loop again? 這個選項嗎?小弟覺得有些麻煩說,如果小弟有個PHA的圖層,那麼放大出來的這個圓可以直接變成PHA層嗎?(圓裡面的物件層不變哦!只是放大的這個圓)
发表于 2004-8-22 00:46:12 | 显示全部楼层
[php]
;;Modified by AIdraft for ljs026
(prompt "\nDETAIL - (c)1998 AUTO-CODE MECHANICAL - *FREEWARE*")
;; FREEWARE Program - you are free to make copies of this and supply it
;;                    to others as is.  Author and company make no
;;                    warrenty on the fitness of this program for anything
;;                    other than using as an example when learning
;;                    AutoLISP.
;; Adapted from the CADENCE January 1999 article by Bill Kramer
;; Detail enlargement macro set.
;; The Main Program
(defun C:DETAIL ( / P1 EN EL PTS SS1)
  (cond
   ;;Set up AutoCAD system variables
   ((DETAIL_0)
      (prompt "\nError in DETAIL_0"))
   ;;Operator input of detail center
   ;;and radius.
   ((DETAIL_1) ;;set up EL, P1, RD
      (prompt "\nError in DETAIL_1"))
   ;;Operator input of detail graphic location
   ;;and scale for detail display.
   ;;Copy detail area, remove non-detail objects
   ;;like dimensions and text, and scale as
   ;;input by the operator.
   ((DETAIL_2) ;;set up P2, SS1, EN, ENT, SCL
      (prompt "\nError in DETAIL_2"))
   ;;Do the trimming of the detail display.
   ((DETAIL_3)
      (prompt "\nError in DETAIL_3"))
   ;;Create the text tag and draw connecting
   ;;line between original area and detail
   ;;area.
   ((DETAIL_4) ;;Output text tag
      (prompt "\nError in DETAIL_4"))
   ('T (prompt "\nDetail finished okay."))
  ;;Reset system variables
  (mapcar '(lambda (X)
      (setvar (car X) (cadr X))) SYSVAR_LIST)
  (prompt "\nUse TRIM to complete if needed.")
  (princ)
;; Listing 2: Set up system variables
(defun DETAIL_0 ()
   (setq SYSVAR_LIST (mapcar '(lambda (X)
     (list X (getvar X)))
     '("CMDECHO"
       "OSMODE"
       "ORTHOMODE"
       "HIGHLIGHT"
   (setvar "CMDECHO" 0)
   (setvar "OSMODE" 0)
   (setvar "ORTHOMODE" 0)
   (setvar "HIGHLIGHT" 0)
   (if (zerop (getvar "TILEMODE")) ;;make sure we are mspace
      (if (= (getvar "CVPORT") 1) (progn ;;we are in paper space!
         (alert "You must be in Model Space for this routine to function!")
         (exit) ;;hard abort!
   (if (zerop (getvar "WORLDUCS"))
     (command "_UCS" "_W"))
   nil
;; Listing 3: Establish area to detail
(defun DETAIL_1 ()
   (setq P1 (getpoint "\nDetail center: "))
   (if P1 (progn
      (prompt "\nShow detail area: ")
      (command "_CIRCLE" P1 pause)
      (setq EN (entlast)
            EL (entget EN)
            RD (if (= (cdr (assoc 0 EL)) "CIRCLE")
                  (cdr (assoc 40 (entget EN)))
                  nil)
      (if RD (progn
         (entdel EN)
         (command "_POLYGON" 15 P1 "I" RD)
         (setq EN (entlast)
               EL (entget EN)
         nil  ;return nil
       1 ;return error level 1.
      ) ;;level 1 is RD not set
    2 ;;return error level 2.
   ) ;level 2 is P1 not set
;; Listing 4: Copy objects to new location
(defun DETAIL_2 ()
   (while (setq TMP (assoc 10 EL))
      (setq EL (cdr (member TMP EL))
            PTS (cons (cdr TMP) PTS)
   (entdel EN)
   (setq SS1 (ssget "CP" PTS)
         P2 (getpoint P1 "\nPut detail at: ")
         CNT (if SS1 (sslength SS1) 0)
   (if P2 (progn
     (repeat CNT
        (if (member
           (cdr (assoc 0
             (entget
                (ssname
                   SS1
                   (setq CNT (1- CNT))))))
           '("TEXT" "DIMENSION"
             "MTEXT" "INSERT"
         (ssdel (ssname SS1 CNT) SS1)
     (command "_CIRCLE" P1 RD
              "_CIRCLE" P2 RD)
     (setq EN (entlast)
           ENT EN)
     (if (tblsearch "layer" "PHA")
        (command "chprop" EN "" "la" "PHA" ""))
     (command "_COPY" SS1 "" P1 P2)
     (setq SS1 (ssadd EN))
     (while (setq ENT (entnext ENT))
        (ssadd ENT SS1)
     (setq SCL (getreal "\nScale factor (2): "))
     (if (null SCL) (setq SCL 2.0))
     (if (/= SCL 1.0)
        (command "_SCALE" SS1 "" P2 SCL)
     nil ;;return nil result, all okay.
    1 ;;return error code 1
   ) ;;error code, P2 not input.
;; Listing 5: Trim the objects copied
(defun DETAIL_3 ()
   (setq TTT 0) ;;change counter
   (while (setq ENT (ssname SS1 0))
     (ssdel ENT SS1)
     (if (not (equal ENT EN)) (progn
        (setq EL (entget ENT)
              PT (DETAIL_3A EL)
        (if (and PT
              (> (distance P2 PT)
                 (+ 0.2 (* RD SCL))))
         (progn
          (setq TTT (1+ TTT))
          (command "_TRIM" EN ""
                   (list ENT PT) "")
;;;     (DETAIL_3B) ;;loop again check
   nil
;; Listing 6: Find point on object for trim
(defun DETAIL_3A (EL / TY)
   (setq TY (cdr (assoc 0 EL)))
   (cond
     ((= TY "LINE")
       (if (> (distance (cdr (assoc 10 EL)) P2)
           (distance (cdr (assoc 11 EL)) P2))
         (cdr (assoc 10 EL))
         (cdr (assoc 11 EL))
     ((= TY "ARC")
       (setq PC (cdr (assoc 10 EL))
             PR (cdr (assoc 40 EL))
             PA (cdr (assoc 50 EL))
             PB (cdr (assoc 51 EL))
       (if (> (distance (polar PC PA PR) P2)
              (distance (polar PC PB PR) P2))
          (polar PC PA PR)
          (polar PC PB PR)
     ((= TY "CIRCLE")
       (cond
         ((> (distance P2
                      (polar PC 0.0 PR))
             (* RD SCL))
            (polar PC 0.0 PR))
         ((> (distance P2
                      (polar PC PI PR))
             (* RD SCL))
            (polar PC PI PR))
         ((> (distance P2
                      (polar PC (* 0.5 PI) PR))
             (* RD SCL))
         (t (polar PC (* 1.5 PI) PR))
     ((= TY "LWPOLYLINE")
       (setq PR nil)
       (while (and (null PR)
                   (setq PA (assoc 10 EL)))
          (setq EL (cdr (member PA EL))
                PA (cdr PA)
          (if (> (distance P2 PA) (* RD SCL))
             (setq PR PA)))
     ((= TY "SPLINE")
       (setq PR nil)
          (setq PA (assoc 11 EL))
                PA (cdr PA))
             (setq PR PA)))
     ((= TY "POLYLINE")
       (setq EL (entget
                  (entnext
                     (cdr (assoc -1 EL))))
             PR nil)
                      "VERTEX"))
          (setq PA (cdr (assoc 10 EL))
                EL (entget
                     (entnext
                 (* RD SCL))
             (setq PR PA)
     ;;add more objects here
   ) ;;end COND for PT assignment
;; Listing 7: Loop control options for user
(defun DETAIL_3B ()
   (if (= (sslength SS1) 0)
      (if (> TTT 0) (progn
         (initget 0 "Yes No")
         (setq TTT (getkword (strcat
              "\nChanged "
              (itoa TTT)
              " objects, Loop again? <Yes>")))
         (if (or (null TTT) (= TTT "Yes"))
            (progn
                    ENT EN)
                (ssadd ENT SS1)
              (setq TTT 0)
;; Listing 8: Finishing touches
(defun DETAIL_4 ()
   (command "_TEXT"
            "_Justify" "_Center"
             (polar P2
                   (* PI 1.5)
                   (+ (* SCL RD)
                      (* 2.5
                         (getvar "TEXTSIZE"))))
   (if (zerop (cdr (assoc 40
              (tblsearch
                 "STYLE"
                 (getvar "TEXTSTYLE")))))
      (command (* SCL (getvar "TEXTSIZE"))) ;;text height output option
   (command 0 ;;finish the TEXT command sequence.
            (strcat "Enlarged "
                    (rtos SCL 2
                      (Best_Prec SCL 0 4))
                    "x")
   ;; Construct line between detail circles.
   (command "_LINE" (polar P1 (angle P1 P2) RD)
            (polar P2 (angle P2 P1) (* RD SCL))
   nil
;; Listing 9: Utility Routine from toolbox
;; Best_Prec - Given a number (NUM) and the
;; minimum and maximum precision, this function
;; returns the precision in the range that will
;; best fit the number.
(defun Best_Prec (Num Mn Mx)
   (while (and (<= Mn Mx)
               (/= Num (atof (rtos Num 2 Mn))))
      (setq Mn (1+ Mn))
   Mn
[/php]
 楼主| 发表于 2004-8-22 21:21:27 | 显示全部楼层
大大真是好人!這這麼好的程序幫小弟解決了困擾的問題!感謝大大
GMT+8, 2026-11-5 01:18 , Processed in 0.516298 second(s), 36 queries , Gzip On.
