查看: 2105|回复: 4
[求助]:在VB中如何给线宽属性(LineWeight)赋值呢?
发表于 2004-8-27 13:27:46 | 显示全部楼层 |阅读模式
如题。下面是我的程序段:
Dim acadApp As Object, acadDoc As Object, moSpace As Object
Private Sub DrawSingal(Pt1 As Double, Pt2 As Double, txtStr As String)
Dim TriSin As Object,Pts(5) As Double
Set acadApp = GetObject(, "AutoCAD.Application")
If err Then
    err.Clear
    Set acadApp = CreateObject("AutoCAD.Application")
    If err Then
        MsgBox "启动AutoCad失败,请检查您的计算机上是否正确安装了AutoCad。", vbExclamation + vbOKOnly, ""
        Exit Sub
    End If
End If
acadApp.Visible = True
Set acadDoc = acadApp.ActiveDocument
Set moSpace = acadDoc.ModelSpace
Pts(0) = Pt1: Pts(1) = Pt2
Pts(2) = Pt1 + hight: Pts(3) = Pt2 + hight
Pts(4) = Pt1 - hight: Pts(5) = Pts(3)
Set TriSin = moSpace.AddLightWeightPolyline(Pts)
TriSin .LineWeight=acLnWt018 ' 执行这一句时提示变量'acLnWt018'未定义,但是acLnWt018是CAD的线宽值呀???????
End Sub
还有一个没有解决的问题,如何给图层设置线宽、线型、颜色呢???谢谢!!!!
发表于 2004-8-27 14:19:22 | 显示全部楼层
你在VBA里直接写
msgbox acLnWt018
看看值多少,把它赋给TriSin .LineWeight
 楼主| 发表于 2004-8-27 15:41:25 | 显示全部楼层
不行,VBA里直接写msgbox acLnWt018,
运行提示“编译错误:acLnWt018 无效外部过程”
发表于 2004-8-27 15:46:05 | 显示全部楼层
Sub j()
MsgBox acLnWt018
End Sub
发表于 2005-10-1 12:05:38 | 显示全部楼层
Set objlayer = ThisDrawing.Layers.Add("主体")
     objlayer.Color = 40
     objlayer.Linetype = "continuous"
     ThisDrawing.ActiveLayer = objlayer
     ThisDrawing.ActiveLinetype = objlayer.Linetype
运行说linetype类型不匹配怎么回事啊?图层和颜色改变了,线型怎么才能随着改变?
麻烦斑竹了!!
GMT+8, 2026-11-3 18:30 , Processed in 0.534319 second(s), 40 queries , Gzip On.
